First post, by Jade Falcon
Rank BANNED
BANNED
http://cdn.overclock.net/6/67/900x900px-LL-67 … _Capacitor.jpeg
Aftermath of a PSU blow out caused by HEC caps/
http://i41.tinypic.com/qy66wy.jpg
http://s24.postimg.org/kijyv3qz9/eurocase_psu_in_action2.jpg
Asus Mobo
http://s21.postimg.org/wpc98bbxj/asus_mobo_bad_caps.jpg
Blown polymer cap
http://www.overclock.net/content/type/61/id/2443801/flags/LL
http://www.overclock.net/content/type/61/id/2443802/flags/LL
Reply 1 of 15, by martin939
This ASUS mobo pic doesn't look like blown cap at all. More like a critical failure of a chip/voltage regulator.
Reply 3 of 15, by Jade Falcon
Rank BANNED
BANNED
Could be, but could have been started by a bad cap.
Reply 4 of 15, by Errius
I had this happen to me once, but the capacitor was on a PCI USB/FireWire card. The explosion destroyed the PCI Matrox graphics card next to it.
"AI Requires Proof That You Are Human"
Reply 6 of 15, by martin939
KT7 is infamous for garbage caps. I have here one with a Duron 600 with just about every cap leaked through the top. Don't want to touch multiplayer PCB mess to recap it, not worth it for me.
Reply 7 of 15, by elod
What kind or PSU exactly? OVP should have kicked in if it had any.
Reply 8 of 15, by cyclone3d
OVP is not going to kick in to prevent the explosive gas from exploding that has formed from the electrolyte degrading.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 15, by cyclone3d
Easy peasy to recap a motherboard. You just need a temp adjustable soldering iron to remove the old ones. You don't even have to use solder wick. You just heat up one leg, use the cap itself to help pull the leg out by tipping the cap the one way and then repeat with the other leg. Usually take 2-3 times with each leg to get it all the way removed. Then once it is out, you can use a solder sucker to remove the left over solder if you really want to. Usually I just install in reverse order without sucking the old solder all the way out of the holes.
I also use solder paste to help with cleaning the solder which also helps immensely with heat transfer to the solder itself so you don't end up burning the board itself when removing the old caps.
YMF7x4 Guide
Reply 10 of 15, by martin939
I know, I do have a professional Ersa soldering station and a vacuum pump desoldering station but it's the cost that holds me back, shipping is more expensive than the components and I hade those tiny soldering pads 😉
What temp is your iron set to for PC motherboards?
Reply 11 of 15, by cyclone3d
I generally order caps off of eBay. Super cheap and shipping is not expensive either. The parts warehouses are just stupid crazy with their shipping prices.
The temp setting varies depending on the motherboard as well as if the connection is on a ground plane or not. Whatever temp makes the solder melt without having to hold the iron in place for very long.
YMF7x4 Guide
Reply 12 of 15, by luisile
Hi can you please send me a link to a reasonable seller of capacitor on ebay? Thanks
Reply 13 of 15, by elod
To get this kind of reaction I think you need a pretty violent and long overvoltage. This is why I think PSUs with separate OVP ICs are safer.
Reply 14 of 15, by elod
http://www.tme.eu/sk/
Farnell has a wider range of components but a bit higher shipping cost (for Romania TME is shipping at around 4 euros, Farnell was 5 if I remember right).
With ebay you'll likely never know if you got the right part vs a cheap chinese knockoff.
Reply 15 of 15, by cyclone3d
Like I said, I had the same exact thing happened as soon as I turned the power on on an NOS KT7A. The instant I pushed the power button 4 or 5 capacitors exploded.
When I did a bit of research before making my first post in this thread, apparently newer capacitors have venting capability so they can release the gas from the electrolyte degrading. The older design didn't have a vent so the gas just stays inside unless the top pops and lets it leak out.
Yeah, I guess it could be from an overvoltage event, but I really doubt it based on past experience.
YMF7x4 Guide
