Modern Gamepad on Gameport?
Postby Xnyle » 2017-8-17 @ 22:03
I just spent the last two hours searching the inter-nets for sone info about USB->Gameport (NOT Gameport->USB) adapters and came up with nothing.
Serioulsy, nobody else want's to use modern Joysticks/Gamepads on old computers?
Or is there some device like the Tom for the Amiga, just for the Gameport and I just didn't find it?
I found USBDOS though but that seems rather beta, I doubt it will work in old games.
Xnyle
Re: Modern Gamepad on Gameport?
Postby Jo22 » 2017-8-19 @ 15:06
To be honest, I've never even thought about this.
It's a cool idea, though. And a great exercise for a weekend project. :cool:
It should be possible to use something like an Arduino Leonardo for that purpose.
If I'm not mistaken, that model has a true USB controller to emulate HID devices.
Maybe it could be reprogrammed to operate in reverse, converting a HID device, like an USB joystick
to an anlogue game pad.
It would essentially provide signals for the digital buttons and two analogue axis unsing the PWM/analogue pins.
This would also require a bit of external electronic on a shield, like some relays/optoinsulators for emulating the
digital gameport buttons and some resistors for the axis.
If only a simple gamepad is to be emulated, a simple d-pad (four directions) could be simulated by
using some simple resistors with fixed values. These would have to be "turned on" by using transistors/a shift register.
A more elegant idea would be to use some special hi-fi ICs for volume control, but I don't know much about them.
Anyway, that's just an idea.
Converting USB to Gameport shouldn't be hard with todays microcontrollers,
you'll only need the "know-how" to do it. ;)
User avatar
Jo22
Postby madrobby » 2018-7-21 @ 11:14
Xnyle wrote:Serioulsy, nobody else want's to use modern Joysticks/Gamepads on old computers?
Just did the same search and I’m really surprised that no one has anything for this. I’d love to use modern gamepads like an Xbox One controller with my old PCs.
Most ideally a converter for this would also have a pass through AT & PS/2 keyboard plug and make the buttons on the joystick programmable as keyboard keys (programming could perhaps happen with a modern PC).
madrobby
Postby root42 » 2018-7-21 @ 12:33
Even better if there also was a converter to other old 9 pin joystick porta. E.g. I want a new gamepad for my Genesis...
Soldering, retro game reviews and more on YouTube and Bonus videos
Me playing games on my 286 and on my Sega MD2 on Twitch
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, schlae AdLib, PC MIDI Card + SC55MkII, XT CF Lite, OSSC 1.6
User avatar
root42
Postby collector » 2018-7-21 @ 14:25
Note for questions involving old hardware a systems you should ask in Marvin. This forum is for old Windows games on *modern* systems. viewforum.php?f=60
User avatar
collector
Postby Stiletto » 2018-7-21 @ 15:24
Moved to Marvin.
do the Fandango!" - Queen
Stiletto
User avatar
Stiletto
Postby firage » 2018-7-21 @ 16:51
root42 wrote:Even better if there also was a converter to other old 9 pin joystick porta. E.g. I want a new gamepad for my Genesis...
The Genesis had good pads available for it. The good ones are among the best d-pad controller ever made.
Emulating a d-pad with a modern analog controller can only be terrible, and modern d-pads are no upgrade from original hardware. The biggest potential here is probably in emulating an analog joystick for racing games and such, all kinds of stuff had joystick support.
User avatar
firage
Postby root42 » 2018-7-21 @ 18:14
Yes, but what if the original pads are worn out or broken? What would you recommend as a replacement?
User avatar
root42
Postby BeginnerGuy » 2018-7-21 @ 19:41
I really like Jo22's idea. I don't have a little SBC to mess with but I don't see why this couldn't be done. I wouldn't mind using an xbox controller to play some DOOM :P. I've been considering buying a raspberry pi just because why not anyway. I'm not aware of how I would interface with the HID controller (read joy position or button state) at the moment, furthest I've gone in recent years has been using SDL to poll the controller.
I could fathom exactly how I would write the driver for it on the DOS, I would want to design it so any basic scratch Joy/2 button gamepad driver works, I've written my own joy drivers many a time.
As far as joysticks though I haven't been studying these things for years, old analog joysticks have a potentiometer + capacitor and you simply time how long it takes to get a voltage out to your pin to calculate the position of the given axis (extremely CPU dependent because of the polling speed, hence the need for calibration). I think this could possibly be done in software on the SBC using delays, but would introduce a little input lag, hopefully not a noticeable amount.
Sup. I like computers. Are you a computer?
User avatar
BeginnerGuy
Who is online
Users browsing this forum: HeavyD8086, jamesp15, keenmaster486, keropi, PcBytes and 10 guests
