First post, by squareguy
- Oldbie
Okay, so I usually post half-baked ideas where I don’t take the time to try and explain myself very well. I will try to do better with this post.
I am looking at building a new Windows XP gaming rig because I had to dismantle my old one (a couple years ago) and make it a Windows 7 box for daily use. Actually I am using it right now.
I have been reading up on Windows XP builds again and I would like to share my take on it and hear some feedback. Right now forget sound cards and video cards, I am just focussing on the core system for the moment.
Single threaded CPU performance trumps all. With that in mind I am only looking at Intel CPUs. Socket 1155 is the last Intel socket with Windows XP support so I will stick with that. The Ivy Bridge i5-3570K is about as fast as you can get without getting exotic (socket 2011). Fast, no hyperthreading, and the price has come down a lot. The main benefit of the i5-3570K might not be its speed but its underclocking potential. I have been reading that some XP games might not like an extremely fast CPU and having an unlocked multiplier can easily solve that.
To make use of a K series CPU I have to use a ‘performance’ chipset. The Intel Z68 is the oldest ‘performance’ chipset I see with Ivy Bridge support. Being older it should have more mature Windows XP drivers than the newer Z77 chipset. I am looking for mATX boards with 1 PCI-e x16, 3 PCI-e x1 and no traditional PCI slots. I may go for a full size board depending on what is available.
Keeping cooling simple with a Cooler Master Hyper 212 EVO CPU cooler and using Arctic MX-4 thermal paste.
RAM will mainly depend on if I end up dual booting the system, so let’s say 4GB+.
A quality power supply somewhere in the range of 550-750 Watts should handle any single GPU and overclocking. I will not be using any multiple GPU configurations.
For the case I just know that it will have good airflow to keep the GPU nice and cool.
Windows XP Pro SP2 will be used since it is the sweet spot and it is the first SP to support multicore CPU’s. Install the latest DirectX 9.0C runtime and call it done. I plan to make a custom install CD with integrated AHCI drivers.
Thoughts / ideas?
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
