dr_st wrote:Because you would be wasting time working around compatibility problems that don't have to be there to begin with. [...] I would understand if he already had the parts. i would understand if he wanted a machine that can also cover WinXP era games, but given the starting point of this thread - it's not an ideal solution. Did not say "impossible". Just "not ideal".
You're missing a really good advantage of starting with a P4 - they are DIRT CHEAP, or often free, and dead-easy to find. Universities and businesses are just throwing them away by the skipload. P2s & P3s, especially ones with ISA slots, are being mercilessly held by the hoarders and are apparently gold-plated if you even find one for sale at all.
If the OP just wants to mess around with some stuff, why not start with a P4? If or when he decides he needs something more compatible, he can go on the hunt then. Trust me, a 1.4GHz tualatin with an ISA slot and a Voodoo5 isn't gonna fall into anyone's lap these days.
dr_st wrote:xjas wrote:There's loads of stuff wanting a nice fast CPU in DOS
No, there isn't. Certainly not on a P4 3GHz level.
Yeesh - I gave you an example in literally the next bullet point you tried to refute. Just about any of the late 3D stuff that runs under DOS likes a ton of horsepower if you crank the resolution. Quake, Hexen 2, various flight sims, Tomb Raider, Carmageddon, Descent 2, even Build games as mentioned. You may not be maxing out a 3GHz P4 on those, but you're certainly gonna get high framerates with no slowdowns. Throw Vsync on and play at 1280x1024 @ 60FPS all day.
dr_st wrote:xjas wrote:Try running Quake at 1024x768 if you want to stress test it.
If the goal it to build a system for benchmarks and stress tests, just so that one can post high numbers and discuss them in endless forum threads - then, yeah, sure. For a machine to actually use for DOS/Win98 - not the best option.
What's wrong with wanting to play Quake in software at ridiculously high res and a good framerate? Who said anything about synthetic benchmarks?
