Well I tried swapping out the ram with a different stick of 128MB PC133 SDRAM and a 128MB PC100. Still nothing. Turned off AGP boost mode. Nothing. Reset CPU to 100 with a multiplier of 4 on the motherboard. Quake benchmark went from 20 fps to 24 fps (640x480). Quake benchmark at 360x480 is a whopping 30fps. Something is seriously wrong. I'm tempted to get a different CPU, this thing seems to be crap somehow.
Here are my speedsys readings.
CPU is in V86 mode: Yes
Processor : AMD K6(tm)III+ 400 MHz
Frequency via TSC : 400.91 MHz
External clock : 100.23 MHz x 4.0
CPUID (TFMS) : 05D0 Codename: Sharptooth(0.18um)
Feature : 008021BFh MMX(tm):Yes, IA SSE:No, IA SSE2:No
Extended CPUID : 06D0
CPU Name String : AMD-K6(tm)-III Processor
Extended Feature : C08029BFh 3DNow!(tm):Yes, 3DNow! Extensions:Yes
L1 Cache size : 64 KB
L2 Cache size : 256 KB
Write Allocate : Enabled
CPU speed index : 430.58
Total memory size : 128 MB (SDRAM PC133)
Memory Bandwidth : 224.30 MB/s
AGP Video : 3Dfx VooDoo3 GUI+3D Accelerator
Support AGP rate : 1x, 2x
Desired AGP rate : 2x
AGP Operations : Enabled
AGP SBA : Supported, Status: Enabled
AGP Fast Writes : Not Supported
AGP Status Reg. : 07000223h
AGP Command Reg. : 07000302h
VESA OEM String : 3dfx Interactive, Inc.
VESA video memory : 16384 KB (47883 KB/s)
Hard drive 0 : 1024C 255H 63S 7.84 GB
ÀÄÄÄÄÄ Model (SM): ST3160212A
Mainboard chipset : Acer ALI M1541 Aladdin V
Mainboard model : ASUS P5A
BIOS vendor : Award Modular BIOS v4.51PG (05/02/02)
OS version : Windows98(tm)
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ
ATA/ATAPI Device Information
IDE0ÄÂÄMasterÄ<ATAPI>Ä LITE-ON LTR-52246S
³ Firmware Revision : 6S0D
³ Maximum Transfer Mode : PIO 4, DMA 2, UDMA 2 (UltraDMA/33)
³ Selected DMA Transfer Mode : DMA 0
³ Maximum Transfer Speed : 9152 KB/s (52X)
³ Selected Transfer Speed : 9152 KB/s (52X)
³ Maximum Write Speed : 9152 KB/s (52X)
³ Selected Write Speed : 9152 KB/s (52X)
³ Cache Buffer Size : 2048 KB
³
ÀÄSlaveÄÄ<Empty>
IDE1ÄÂÄMasterÄ<ATA-7>Ä ST3160212A
³ Cylinders: 16709, Heads: 255, Sectors: 63 (128.00 GB)
³ Serial Number : 5LS3K3CV
³ Firmware Revision : 3.AAE
³ Maximum Transfer Mode : PIO 4, DMA 2, UDMA 5 (ATA-100)
³ Selected DMA Transfer Mode : DMA 2
³
ÀÄSlaveÄÄ<Empty>
IDE2ÄÂÄMasterÄ<Empty>
³
ÀÄSlaveÄÄ<Empty>
IDE3ÄÂÄMasterÄ<Empty>
³
ÀÄSlaveÄÄ<Empty>
Memory Modules Information
SMBus/i2c Host Controller : ALI M7101, I/O: E800h
<Slot 0>
ÀÄÄÄÄÄ SPD-EEPROM Checksum : OK
Memory Module Size : 128 MB
Memory Type : SDRAM PC133
Technology : 8x[16Mx8], 128 Mbit
SDRAM Cycle time (tCYC) : 7.5ns (133 MHz)
SDRAM Access time (tAC) : 5.4ns
Supported CAS# Latency : 3 (up to 133 MHz)
Supported CAS# Latency : 2 (up to 83 MHz)
Min. Row Precharge Time (tRP) : 20ns (2T up to 100 MHz)
Min. RAS to CAS Delay (tRCD) : 20ns (2T up to 100 MHz)
Min. RAS Pulse Width (tRAS) : 44ns (5T up to 114 MHz)
Label : PC133U-333-541
Manufacturer : SpecTek
Manufacturer's Part Number : Not Present
Serial Number : Not Present
PCI/AGP Device Information [PCI 2.10, AGP 1.0 (2x)]
[00-00-0]
ÀÄÄÄÄÄ VEN_10B9, DEV_1541, REV_04, SUBSYS_154110B9
Acer Labs ALI M1541 Aladdin V/V+ AGP+PCI North Bridge
Class Code : 060000 - PCI to Host Bridge
Memory Base Range 0 : E0000000 - E3FFFFFF (64MB)
[00-01-0]
ÀÄÄÄÄÄ VEN_10B9, DEV_5243, REV_04
Acer Labs ALI M1541 PCI to AGP Bridge
Class Code : 060400 - PCI to PCI Bridge
[00-02-0]
ÀÄÄÄÄÄ VEN_10B9, DEV_5237, REV_03, SUBSYS_00000000
Acer Labs ALI M5237 OpenHCI USB Controller
Class Code : 0C0310 - USB (OHCI)
Memory Base Range 0 : DD800000 - DD800FFF (4KB)
[00-03-0]
ÀÄÄÄÄÄ VEN_10B9, DEV_7101, REV_00, SUBSYS_710110B9
Acer Labs ALI M7101 Power Management Controller
Class Code : 068000 - Other Bridge
[00-07-0]
ÀÄÄÄÄÄ VEN_10B9, DEV_1533, REV_C3, SUBSYS_00000000
Acer Labs ALI M1533 Aladdin IV/V ISA South Bridge
Class Code : 060100 - PCI to ISA Bridge
[00-11-0]
ÀÄÄÄÄÄ VEN_1102, DEV_0004, REV_03, SUBSYS_00511102
Creative Labs SB0090 Audigy Platinum Digital Audio
Class Code : 040100 - Multimedia Audio Adapter
I/O Base Range 0 : B800 - B81F (32)
[00-11-1]
ÀÄÄÄÄÄ VEN_1102, DEV_7003, REV_03, SUBSYS_00401102
Creative Labs Audigy Series Gameport Joystick
Class Code : 098000 - Other Input Device
I/O Base Range 0 : B400 - B407 (8)
[00-11-2]
ÀÄÄÄÄÄ VEN_1102, DEV_4001, REV_00, SUBSYS_00101102
Creative Labs Audigy Series Firewire Controller
Class Code : 0C0010 - OHCI FireWire Serial Bus
Memory Base Range 0 : DD000000 - DD0007FF (2KB)
Memory Base Range 1 : DC800000 - DC803FFF (16KB)
[00-15-0]
ÀÄÄÄÄÄ VEN_10B9, DEV_5229, REV_C1, SUBSYS_00000000
Acer Labs ALI M5229 EIDE Controller
Class Code : 01018A - IDE Controller
I/O Base Range 4 : B000 - B00F (16)
[01-00-0]
ÀÄÄÄÄÄ VEN_121A, DEV_0005, REV_01, SUBSYS_003A121A
Class Code : 030000 - VGA Compatible Adapter
Memory Base Range 0 : 14000000 - 15FFFFFF (32MB)
Memory Base Range 1 : 18000000 - 19FFFFFF (32MB)
I/O Base Range 2 : 3000 - 30FF (256)
ISA PnP Device Information
Card Vendor ID Serial No ANSI ID String
1 CTL009E 11ECA368 Creative SB AWE64 Gold
End of report.
