First post, by Jade Falcon
So there are two systems I never build or messed with before.
Pentium pro and a back plane system, this winter I'll build one of the two, or both 😕
I was thinking of getting a PICMG board like this.
http://www.ewayco.com/26-Backplanes-PCI-ISA-P … /PCI-8S_500.jpg
Anyway I was wondering if anyone had any advice or links to info on older backplane setups?
Thanks
EDIT:
Some things I'd like to know.
Can I disabled the video card on the PICMG cpu board and use a better PCI card?
Can I use any PCI/ISA card with such a setup? Or do I need special hardware?
Can I use two PICMG cards in the same system for a dual CPU setup? Or are the second cpu board slots for redundancy?
