IPX network on MS-DOS
Reply 42 of 50, by Deksor
You can start and stop IPX on the fly, why would you put that in your autoexec.bat ?
You can simply make "startipx.bat" and "stopipx.bat" containing the three lines to start and stop ipx when you don't need it anymore ^^
alternative
Reply 43 of 50, by Guybrush3pwood
Deksor wrote on 2020-02-01, 22:05:
It’s not as slick, but I guess it’ll have to do. What does the stopipx batch file look like? Not sure of the command that would end what the com files do.
Reply 44 of 50, by Deksor
IIRC, just type the commands in the opposite order with parameter "/u" to unload each of them.
alternative
Reply 45 of 50, by chinny22
Guybrush3pwood wrote on 2020-02-01, 16:59:
Oh man, nevermind, that worked. I COULD KISS YOU!!! I won't, but I could!
Now, is it just as easy to get TCP-IP working?
Just happy to help, No need for the affection 😉
TCP is totally different.
What you have actually done is load the files needed to connect to a Netware server (That's why the NWCliennt folder name)
We don't have any way of sharing files etc.
If you want TCP you need more software. Microsoft Network Client 3.0 or ftp via MTCP are common options these days but also need different drivers loaded.
or do what I do and setup TCP in Win3x.
ftp is easiest to get working with modern OS's and quicker, Win3x feels more fun/retro
I also think this is whats causing windows to hang. if you try win /n to go into windows and see if it hangs
Reply 46 of 50, by Guybrush3pwood
chinny22 wrote on 2020-02-02, 12:47:
Just happy to help, No need for the affection ;) TCP is totally different. […]
A lot has happened since my last post. I'm no expert, but I suspected that my hang had something to do with loading my device driver and a conflict with whatever "NET START" was doing at the beginning of my autoexec.bat script. I REM'd it out as a test and sure enough, it wouldn't hang. So I decided it may be an issue with my NIC. Swapped out the PCI NIC I had in there with an older ISA NIC, thinking that if it could autodetect it, it may be more compatible. Long story short, same issue. So since I had more PCI NICs than ISA NICs, I went back to a PCI NIC, just a different one because why not? Now, this happens:
If I run my IPXSTART.bat script, I can go into Quake in DOS and play a network game no issues. When I exit out of Quake and run IPXSTOP.bat, then try to launch into WFW 3.11, it crashes and reboots my machine, at which point I'm able to type WIN and get in. Simple running IPXSTART.bat and then IPXSTOP.bat doesn't result in the same issue, I have to actually go into a game, play it against another networked computer, and then exit. Typing WIN will crash the system every time. Tried your suggestion by typing WIN /N and still got the crash.
So this three file IPX thing just does not seem to get along with NET START and Windows 3.11. Not really sure what to do about it at this point, but if you have any ideas I'm open to trying them.
Reply 47 of 50, by chinny22
It's strange as the 3 files loaded for dos gaming should happily coexist with windows, but that doesn't help you .
Quick and dirty fix is only load whichever you need. Even though my ipxstart and net start work happily together I only load them when needed. In my case its to free up conventual memory but still it's pretty rare I'll need windows networking and play a network game in the same session and if you do a quick reboot should be enough.
The bigger question is do you have/want networking up and running in windows? if you dont you can leave Net Start disabled as it's only needed for Windows, It wont stop dos network gaming from working in fact It'll free up some resources.
If you do want networking up and running in windows long term thats cool, maybe sort that out without ipxstart loaded first and see if windows behaves then see if it gets along with ipxstart.
Reply 48 of 50, by Retro_retro
elianda wrote on 2017-09-22, 04:36:
Ethernet FRAME type is set to the same on all participating computers, the line looks like:
FRAME ETHERNET_802.2
Thanks! This specific line helped me out with my issue! I’m doing a retro network with 2 old mac’s and a retro pc win98 and couldn’t play C&C (1995) cross-platform. Only the mac’s could join each other, not the pc. I had ipx installed on all machines but thanks to you I changed the ipx ethernet settings from 802.3 to 802.2 and then the pc was able to see and join the game! Thank you so much👍
Reply 50 of 50, by chinny22
How did I not think of that!?
I got a G4 to try out mac versions of games but never thought about C&C and that's my all time favourite game.
and it never crossed my mind to try networking mac and dos games, this is an awesome idea!!!
