Reply 20 of 62, by kanecvr
- Oldbie
wrote:Well, the latest Biostar BIOS worked on my original version MB-8433UUD. Try running your board at 33 MHz and adjust the CMOS settings.
I'm pretty sure that chips marked as Cyrix 5x86-120/4x were originally meant to be Cyrix 5x86-133/4x chips, but they failed to qualify at 133 MHz. So the 120/4x chips were specifically tested and failed at 133 MHz. The Cyrix 5x86-120/3x chips would not have been tested at 133 MHz, so there is a greater chance of getting the 5x86-120/3x chips to run at 133/2x.
Cyrix 5x86-133/4x chips are a lot rarer Voodoo 5 boards, so I don't think anyone would make that trade.
From what I've seen, V5 boards are rarer in my neck of the woods. Every collector that has one has imported it. I know a couple of guys in romania who own 133Mhz cyrix chips - odd ones too - one just says "Cyrix" on it - maybe an engeneering sample? An the other guy has the regular labeled version. In fact I believe he has two of them. There's also a couple of guys in russia that have some of these - saw the posts on CPU world - but none of them will sell/trade.
I'm hoping I'll come across someone with more interest in 3dfx parts then in 486 gear, witch is not uncommon. Frankly I know way more collectors interested in video cards in general rather then 486 stuff. For them a V5 5500 is of greater value then a fast 586.
wrote:I had an Amptron/Elpina UMC chipset board and a 5x86-100... Now after a few months of owning it, sometime in 96, I stumbled across the higher clock settings and ran it at 2x60, I also found 66Mhz, I think, thing was, it didn't actually seem quite as fast at theoretical 133 as 120, benchmarked slightly lower, I guess it was extra wait states or something starting to kick out recoverable errors. Apart from that it did seem to run okay if you kept it cool. I had a clip on fan jammed on bonded on heatsink.
(Thanks very much for documenting the high clock speeds on here, just about everyone I ever tried to tell about them called me a n00b, liar or crazy.)
Feipoa did it first. He has a few threads here on vogons dedicated to these chips and fast 486's in general.
wrote:What an incredible coincidence, as I have been doing exactly that. You need to set the Keyboard controller to Award in Modbin ot […]
wrote:How did the LS486e BIOS workout on the 4DPS? You might need to modify the LS486e BIOS using modbin to allow for the PS/2 mouse. There is a checkbox you need to tick.
What an incredible coincidence, as I have been doing exactly that. You need to set the Keyboard controller to Award in Modbin otherwise it won't work.
Other than that You lose 40Gig hdd support and gain the Y2K bug.
That was with the LS486E-D bios.I am playing around with other bioses so will update this when I have some success.
Do keep us posted please. Thanks for the tip about the KB controller. Personally I'm hoping the Lucky Star bios is better put together and will help with overall stability. Maybe even EDO support?
