First post, by anamyd
Hi, first post here 😀
I recently acquired a workstation PC from a friend of a friend who had been allowed to take it home from his job at a well-known company over 10 years ago and had finally decided to part with it. When i got it, it had the following specs, having already had some upgrades here and there over the years:
2 feet (24 inches) tall white full size ATX tower case (1997)
235-250w (something like that) Power Man PSU (1997)
Tyan Thunder 2 S1696D Dual Slot 1 440LX motherboard with AMIBIOS (1997)
Dual 333MHz “Deschutes” Intel Pentium II Slot 1 CPUs with “passive-style” Intel heatsinks (1998)
Original “Cooltium” fans on the Intel heatsinks (1998)
512MB (4x 128MB) of Micron PC100 SDRAM (1999)
Matrox G400 32MB AGP graphics card (1999)
PCI slot external SCSI connector (all internal non-floppy drives are IDE)
PCI “Ethernet card” (sorry for not being specific with that)
Promise Ultra100 PCI IDE controller
Samsung 3.5” 1.44MB floppy disk drive (2001, for some reason?!)
Iomega IDE ZIP250 drive (2000)
AOpen 52x CD-ROM drive (2000)
LiteOn CD-RW drive (May 2002)
IBM Deskstar 46.1GB, Maxtor 80GB and Maxtor 120GB hard drives (dated 2001-2005 IIRC)
Grey floppy, IDE and SCSI cables
I completely disassembled the system, cleaned all of the parts, put the system back together, replacing the PSU with an internally checked and cleaned out Cooler Master RS-500-PSAP-J3 (circa 2009) because I didn’t feel comfortable using the original 20-year-old PSU, and the system POSTed and went into the BIOS setup fine (apart from complaining that the CMOS battery needs replacing, which I will do) but I still haven’t installed any operating systems yet because the POST screen states “Pentium II, 333MHz. 524288KB OK” when from what I read with the dual CPUs it should state “Pentium II x2, 333MHz. 524288KB OK”. Could anyone who knows what the problem is please tell me...? I’m worrying that it’s the PSU not having a strong enough rail for whatever voltage the CPUs run at (something I read). If it is that, could anyone recommend a suitable PSU...? I heard AOpen ones were good but the one from my P4 had coatings / insulation flaking off a coil and a resistor respectively so didn’t feel comfortable trying that.
By the way I’ve since made my own upgrades to the system so its current spec is:
***Cooler Master RS-500-PSAP-J3 ~450w PSU (circa 2009)***
***Gelid Solutions Silent 5 CPU fans on the Intel heatsinks (2017)***
***Dual 12MB 3DFX Voodoo2 PCI 3D accelerators in SLI (1998)***
PCI “Ethernet card” (sorry once again for not being specific with that)
***Creative Sound Blaster AWE32 CT2760 ISA sound card (1994)***
Samsung 3.5” 1.44MB floppy disk drive (2001, for some still-unknown reason?!)
***Relisys 16x DVD-ROM drive (2002)***
***LG CD-RW drive with more “period correct” speed ratings than the LiteOn (January 2002)***
(OK so more of a downgrade but single 120GB Maxtor hard drive (2005?) - others went into my single PII and P4)
***Arctic Cooling F8 Silent rear exhaust fan (2016) - yeah... my excuse is, the screw holes were on the vent 😜***
I plan on partitioning the hard drive and finally installing the operating systems - Windows 95 OSR2.5, Windows NT 4.0 SP6a, and Windows 98SE, for (respectively) “real” games that don’t run on NT 4.0 (e.g. the first few of the Tomb Raider sequels), ones that do (a surprising amount, including Unreal, Unreal Tournament, Quake II and Quake III, the latter one of which with the SMP command typed will fully utilise both CPUs, right?), and those infamous “casual” games that somehow demand more CPU power as well as not running on 95. Yes, I’m guilty of having popped some caps, but PC is how I played them growing up and my P4 would be overkill for them, 🤣...
In fact, aside from putting 32(28)MB of RAM in my AWE32, I’m thinking of doing a CPU upgrade (once we know for definite why only 1 of the 2 333MHz Pentium IIs is being detected). After reading up on it, it seems that a couple of 533MHz “Mendocino” Intel Celeron “non-A” Socket 370 CPUs (66MHz FSB, 128KB cache) on a couple of Slockets would be the best-performing option compatible with my 440LX-based dual Slot 1 board. Does this sound right...? I read that with 66MHz FSB-only boards such as ones that are 440LX-based, the faster to fastest clocked 66MHz FSB Celerons (433MHz straight onto Slot 1 or 466-533MHz on Slockets) do significantly (relatively speaking) outperform the fastest-clocked 66MHz FSB Pentium IIs (333MHz) despite being “lower end” CPUs, due to the combination of higher clock speed and the lesser amount of cache running at full speed rather than half speed. I also understand that the “non-A” Celeron 533s also happen to be the last Celerons to support SMP operation.
Help with both my CPU detection issue and my CPU upgrade plan would be much appreciated! Thanks 😀
EDIT: By the way, I already have two Slockets - one is an ABIT SlotKet !!! and one is a generic / no-brand one. Would it be possible to use both of these even though they’re not identical ones...?
