Win98 / WinXP P4 build - why wouldn't this work?
Discussion about old PC hardware.
Postby Tmp2k » 2017-10-21 @ 20:26
Hi all, I've been lurking for a while, I bought a Compaq P3 for £10 a few weeks ago and got it looking and running like new. I now know that P2/3's are going for a premium on eBay so pretty chuffed with myself :D
Anyway, I now want to try something else. I'm aware you can build a P4 Win98 rig using the 865G chipset, I was initially looking at socket 478, the Dell GX270 SFF looked an ideal candidate, but then I realised you can get LGA775, so I bought this -> https://www.asus.com/us/Motherboards/P5P800VM/overview/ It came with a P4 3.2GHz and 2GB RAM all for £10 :D
So I'm thinking I dual boot Win98 / XP. that way I can play anything. I can limit 98 to just see the first 512MB RAM and I believe it will work with HT/Dual-core just on one core. Then XP will use both cores and all the RAM.
I'm sure there's a reason that P2/3's are all sold out, and you can pick up the top-spec P4 for £7, but I can't see why this isn't going to work.
Also, what do people think the best LGA775 CPU is? I'm looking at the Pentium D 450 - it's 3.4GHz, dual-core, 95W.
Tmp2k
Re: Win98 / WinXP P4 build - why wouldn't this work?
Postby emosun » 2017-10-21 @ 21:07
Tmp2k wrote:Also, what do people think the best LGA775 CPU is? I'm looking at the Pentium D 450 - it's 3.4GHz, dual-core, 95W.
Core2 Extreme X9775 was the fastest I believe
User avatar
emosun
Postby Tmp2k » 2017-10-21 @ 21:20
There aren't any Core2 CPUs on that board's compatibility list, just Pentium 4/Celeron/ Pentium D. Although is that just because the list was made before Core2 and they would actually work?
Tmp2k
Postby Tmp2k » 2017-10-21 @ 21:35
Just looking into it now and that mobo lists an 800mHz FSB, most the Core2s have a faster FSB so I wonder if I'd be limited to the 800mHz FSB - in which case I'd be looking at an E4700. I'm just speculating here, hopefully someone will know more!
Tmp2k
Postby emosun » 2017-10-21 @ 21:43
if you were wondering what the fastest cpu for that specific board was you should specify that
aparently the board has support for the 65nm pentium D. the fastest 65nm was the Pentium D 960. it's a tossup if that spcific model will work but supposedly it should.
the board doesn't appear to support core 2 cpu's at all.
User avatar
emosun
Postby Tmp2k » 2017-10-21 @ 21:58
emosun wrote:if you were wondering what the fastest cpu for that specific board was you should specify that
Sorry, I thought that would be inferred when I stated I had just bought that mobo and included a link to it. I just bought the Pentium D 945 for £6.50, looks to be the best bet from what was available, just seen a lot of people complaining they run hot and aren't very efficient. I don't know if I'm just wasting that extra core though, or if HT would have been more use. Bearing in mind 98/XP, although with this spec I might try Win7/10 just to see if it runs :D
Could I really run Win 3.1 and Win10 on the same HW? Lets find out :D
Tmp2k
Postby Jo22 » 2017-10-21 @ 23:06
Win 3.1 runs fine on VMs with i5 and i7 CPUs, so I think it's perfectly possible. :D
I heard, on real hardware, the 64-Bit processsors could be problematic, though.
In that case, just run it in Standard Mode instead (win /2 or /s).
User avatar
Jo22
Postby agent_x007 » 2017-10-21 @ 23:14
Tmp2k wrote:Could I really run Win 3.1 and Win10 on the same HW? Lets find out :D
Yes you can, and I can prove it.
Here's my thread about doing it on something newer : viewtopic.php?f=25&t=56460
No VMs were used to make this possible.
As for your setup :
512MB limit should work OK (for the most part), however GPU might present a problem.
What exactly you want to use for this rig ?
User avatar
agent_x007
Postby Tmp2k » 2017-10-22 @ 08:53
Here's my thread about doing it on something newer : http://www.vogons.org/viewtopic.php?f=25&t=56460
As for your setup :
TBH I've not really got a use in mind, I'm just enjoying the challenge and finding the right HW, it's a bonus that so far it's only cost me £16 lol I guess my goal is to build a system that will boot as many retro OSes as possible and be as fast as possible (for the modern OSes) but still compatible with the older ones. I'll probably use it for playing various old games, or maybe just set it up at my local hackspace to show people what Win 3.1/98/xp etc was like.
What's the possible problem with GPUs? I was thinking of going for a Radeon 9550 or 9800 pro (depending on if I go for a low profile case or not). Is there a better choice?
Tmp2k
Return to General Old Hardware
Who is online
Users browsing this forum: Eleanor1967, jheronimus, OldCat, xjas and 9 guests
