Good power supply for a P2 with ISA?
Discussion about old PC hardware.
Postby och » 2017-10-22 @ 23:19
Thinking of building a Pentium 2 system, but it seems that all modern power supplied lack -5 rail on the 20pin connector (essentially making them 19pin)? I really don't want to resort to using an older used power supply. What are my options?
och
Re: Good power supply for a P2 with ISA?
Postby BitWrangler » 2017-10-22 @ 23:44
There is very, very few uses for the -5V, unless you've got a 286 or below or you're very sure you need it for something, then don't worry about it. Unless you've got a nasty board that actually looks at all the voltages and throws a wobbly about the one it will never use.
It is fairly easy to rig a -5V supply off the -12V though.
Basement full of ancient PC stuff, starting to go through it. Most recently toyed with DOS era stuff 15 years ago, so memory might be rusty. So what's this BitWrangler guy's deal ??? >>> http://www.vogons.org/viewtopic.php?f=25&t=56382
User avatar
BitWrangler
Postby gdjacobs » 2017-10-23 @ 00:14
You can find new Startech ATX 1.3 supplies with appropriate rail allocations for Athlon 3200+ type machines and -5V rails. There should also be some availability of FSP/SPI supplies of the same design era as they were still in production until fairly recently. If your P2 board uses AT, Startech makes those new as well.
User avatar
gdjacobs
Postby och » 2017-10-23 @ 09:53
So I should be ok running ISA Awe64 gold using a power supply without -5v?
och
Postby Koltoroc » 2017-10-23 @ 12:51
Yes. The AWE 64 does not use -5v. actually most creative labs soundblaster cards don't use it AFAIR the last to do so was the Soundblaster 2.0.
Koltoroc
Postby gdjacobs » 2017-10-23 @ 16:22
och wrote:So I should be ok running ISA Awe64 gold using a power supply without -5v?
There's a thread for that.
User avatar
gdjacobs
Postby .legaCy » 2017-10-24 @ 13:34
If i recall correctly modern psu has -12v , modding the power supply atx connector and using one 7905 regulator you can create a weak -5v
User avatar
.legaCy
Postby BitWrangler » 2017-10-24 @ 15:33
.legaCy wrote:If i recall correctly modern psu has -12v , modding the power supply atx connector and using one 7905 regulator you can create a weak -5v
-5 is kinda weak anyway, and 7905 is good for an amp, depends how crappy the -12V is, I've seen as bad as 300mA so you won't get much out of that, if it's 1A that's nice because average for each was half an amp.
User avatar
BitWrangler
Postby gdjacobs » 2017-10-24 @ 15:59
There are switching regulators to invert the polarity as well. See charge pump and buck-boost configurations.
User avatar
gdjacobs
Postby .legaCy » 2017-10-24 @ 18:24
gdjacobs wrote:There are switching regulators to invert the polarity as well. See charge pump and buck-boost configurations.
If you look for premade modules is kind of okay and way more efficient than a linear regulator(7905), but for diy its kind of way harder to design a buck-boost converter
User avatar
.legaCy
Postby gdjacobs » 2017-10-25 @ 03:24
Premade modules are definitely the easiest, but most VRM application notes have a baseline design that you can roll with.
User avatar
gdjacobs
Return to General Old Hardware
Who is online
Users browsing this forum: debs3759, Nprod, Skyscraper and 11 guests
