First post, by GiSWiG
So I'm trying to build a high-performance Windows 98, or if needbe Windows ME.
I'm trying to use:
Athlon 64 3000+ 2.0GHz
Quadro FX 3000
Audigy 2 ZS
TB Aureal Vortex 2
512mb RAM (256x2 or 512x1)
So the motherboard is in question. I was trying to use an ASUS K8V Deluxe with the VIA K8T800 chipset but it seemed finicky but that could be issues with the board. So I got an ASRock K8NF3-VSTA with an nforce 3 250 chipset.
On the ASUS, it wasn't bad but it wasn't great. I'll have to switch the board around again and try again, but last I knew, it was not nice and stable.
On the ASRock, it started to crash on boot after installing the Aureal drivers. I tried several versions, using the Turtle Beach and the reference and I had physically removed both sound cards. I tried a second time, installing the Audigy first but I had similar issues. I tend to thing it was related to the nvidia USB drivers but I installed the generic drivers for flash drives to work in 98SE, which they did at first.
So I'm wondering if others have had similar issues and how you resolved them. I was thinking of trying Windows ME but I'm not sure if there are compatible or stable Vortex2 drivers. Also, is there a recommended unofficial Windows ME Service Pack?
Thanks!
Steamer/GOG-er: ASUS Crosshair IV Formula | AMD Phenom II X6 1100T 3.7GHz all cores | Mushkin 8GB DDR3 RAM 1333 w/ 6-6-6-18 1T | Dual AMD Radeon HD 6850s in CrossFireX | X-Fi Titanium | Dual-boot Windows XP and Vista
