Anyone got a FIC PA-2013 supersocket7 motherboard?
Postby Cga.8086 » 2017-11-09 @ 15:58
i searched for drivers everywhere and could not find any, just bios updates.
and then i saw this FIC FTP that has a lot of things:
ftp://ftp.fic.com.tw/motherboard/driver/
manual:
ftp://ftp.fic.com.tw/motherboard/manual ... 7/pa-2013/
bios:
ftp://ftp.fic.com.tw/motherboard/bios/socket7/pa-2013/
drivers:
Jan 08 2013 18:03 = 1stUtilities_v1.0
Jan 08 2013 18:02 = 1stUtilities_v1.01
Jan 08 2013 18:01 = 1stUtilities_v1.02
Jan 08 2013 18:00 = 1stUtilities_v1.1
Jan 08 2013 17:58 = 1stUtilities_v1.11
Jan 08 2013 17:57 = 1stUtilities_v1.2
Jan 08 2013 17:56 = 1stUtilities_v1.21
Jan 08 2013 17:54 = 1stUtilities_v1.22
Jan 08 2013 17:53 = 1stUtilities_v1.23
Jan 08 2013 17:51 = 1stUtilities_v1.231
Jan 08 2013 17:50 = 1stUtilities_v1.241
Jan 08 2013 17:46 = 1stUtilities_v1.25
Jan 08 2013 17:45 = 1stUtilities_v1.26
Jan 08 2013 17:43 = 1stUtilities_v1.261
Jan 08 2013 17:41 = 1stUtilities_v1.262
Oct 11 2011 15:36 = 1stUtilities_v1.27
Jan 08 2013 17:37 = 1stUtilities_v1.271
Jan 08 2013 17:36 = 1stUtilities_v1.272
Jan 08 2013 17:34 = 1stUtilities_v1.28
Jan 08 2013 17:32 = 1stUtilities_v1.29
Jan 08 2013 17:26 = 1stUtilities_v1.291
Jan 08 2013 17:25 = 1stUtilities_v1.292
Jan 08 2013 17:24 = cd_pro_v4_1
Jan 08 2013 17:24 = cd_pro_v4_2
Jan 08 2013 17:23 = cd_pro_v4_31
Jan 08 2013 17:21 = cd_pro_v5_1
Jan 08 2013 17:21 = cd_pro_v5_2
Jan 08 2013 17:18 = cd_pro_v5_3
Jan 08 2013 17:16 = cd_pro_v5_31
Jan 08 2013 17:14 = cd_pro_v5_32
Jan 08 2013 17:12 = misc
Jan 22 2012 11:00 471 PT-2200_Pentium_166_Jumper_Setting.txt
im not sure what 1stutilities version is the one for PA.2013 and what cd_pro
can anyone help,maybe someone has the driver CD ?
Cga.8086
Re: Anyone got a FIC PA-2013 supersocket7 motherboard?
Postby Ozzuneoj » 2017-11-09 @ 17:28
Its probably not much help, but I don't recall installing any drivers for my PA-2013 on Windows 98SE, aside from the ones that Windows had built in.
Time Machine = FIC PA-2013 2.1 - K6-2 500 - 256MB PC-100 - TNT2 Pro 16MB AGP - Labway Yamaha YMF719-E - Midiman MM401
Amibay For Sale Threads
I have lots of PC stuff for sale on Mercari! Get a $10 sign up credit with invite code VBGQMM.
User avatar
Ozzuneoj
Postby AmiSapphire » 2017-11-09 @ 21:59
I actually do have that motherboard (Rev. 2.1). [I also mirrored their entire FTP server 3 years ago.] I never installed such drivers for Win98SE from when I tested the board years ago, though. They did move their very old stuff here:
ftp://ftp.fic.com.tw/motherboard/driver/misc/utilities/
VIA IDE drivers are in /busmaster/
VIA AGP drivers are in /agp/
VIA PCI MINIport drivers are in /miniport/
VIA USB drivers are in /usb/
Later via_580_2144 IDE drivers aren't present, though they are in driverguide. Those are attached.
There's supposed to be a Functions Registry download for the MVP3 chipset for Win9x, but I cannot locate that in the FTP server. Attached.
Recently found IDE drivers 2.1.49.1, now attached.
Other later drivers for some devices are in CD-Pro archives in ftp://ftp.fic.com.tw/motherboard/driver/ subdirectory. 1stUtilities archives seems to post-date most CD-Pro archives on the server, but some drivers for that board may be in earlier 1stUtilities archives. Apparently, recommended VIA 4-in-1 drivers for MVP3 and Win98SE are v4.35, located right here.
Reference regarding the VIA 4-in-1 drivers:
viewtopic.php?f=46&t=47882
IDE_MVP3_Driver_Win9x_WinNT4.rar
Version 2.1.49.1
(710.31 KiB) Downloaded 14 times
VIA_Chipset_Functions_Registry_Win9x.rar
(823.83 KiB) Downloaded 13 times
580_2144.exe
Updated 12/06/99
This driver resolves IDE device incompatabilities, but does not enhance performance.
Also Supports NT
(739.59 KiB) Downloaded 10 times
Computer in my collection that had too much work done is... Compaq Armada 1573DM!
- Original DSTN panel replaced with an HPA panel
- Left hinge repaired twice
- Front panel replaced twice as a result of the left hinge issue
- Replaced busted inverter
User avatar
AmiSapphire
Postby BloodyCactus » 2017-11-10 @ 14:48
I have the 2.1 and only did the bios update. As noted, you only need the VIA driver, nothing else is specific to the fic motherboard that you need stuff from their ftp site.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
User avatar
BloodyCactus
Who is online
Users browsing this forum: MCGA and 5 guests
