Cant find drivers or any information for a Gateway GP7-650. Any help?
Discussion about old PC hardware.
Postby andreja6 » 2017-11-09 @ 22:17
So my friend took his old PC out of storage to install windows 98 on it. Needless to say there were a myriad of issues, especially the fact that windows 98 cant detect the CD drive that it was installed on. (genius) We can't find any drivers, manuals, or anything for it. Does anyone know anything about this particular machine?
andreja6
Re: Cant find drivers or any information for a Gateway GP7-650. Any help?
Postby cyclone3d » 2017-11-09 @ 22:42
Well, if it has the stock motherboard and CPU, it is an Intel (440BX based - edit: may be newer. Was unable to find a picture that shows a closeup of the board) Slot 1 motherboard with a Pentium III 650Mhz CPU.
Here is a magazine post that lists it.
https://books.google.com/books?id=oUEVDwGvQ-8C&pg=PA42&lpg=PA42&dq=gateway+gp7-650&source=bl&ots=lyoV-0atfO&sig=AJ7pJMR6cg-d43t7dvDWDkK79kw&hl=en&sa=X&ved=0ahUKEwjcu9iMx7LXAhUm94MKHT3FB5UQ6AEITDAJ#v=onepage&q=gateway%20gp7-650&f=false
You may need to open it up to see if the CD-ROM drive is hooked up to a sound card.
Pics of the inside would help a lot.
User avatar
cyclone3d
Postby AlaricD » 2017-11-09 @ 22:50
That has an Intel chipset, like an 810 or 815 I think; Intel still has drivers for chipsets from that era for Win98. https://downloadcenter.intel.com/downlo ... oduct=1145
Be sure to REM the CD-ROM driver in CONFIG.SYS and the network redirector (typically MSCDEX.EXE) in AUTOEXEC.BAT, else it may use MS-DOS compatibility mode.
Depending on the IRQ/IO ranges specified on the CD-ROM driver, it may be connected to an audio card-- but Win9x should recognize IDE controllers on audio cards by itself, typically.
By "Win98 can't detect the CD drive it was installed on", what do you mean? Installed FROM? Booted from?
Welcome to the Eclipse(C). The Evolution of an Idea
Options: DCM3 LCR VMS CVM Sil CPI VMI ANI 648 CA1 SACD500 Att CID RLS TIME DLG
Version: ECLIPSE 2.0.0 09/09/98 System is BUSY Thu 07-21-05 1:31 pm
Access Level = 10 Port = 10
User avatar
AlaricD
Postby andreja6 » 2017-11-09 @ 22:53
AlaricD wrote:That has an Intel chipset, like an 810 or 815 I think; Intel still has drivers for chipsets from that era for Win98. https://downloadcenter.intel.com/downlo ... oduct=1145
It doesn't detect the CD drive it was installed from* The motherboard is the stock board that came with it. I will post some pictures, and check to see. DOes it matter if it is on primary or secondary IDE? Master or slave?
andreja6
Postby andreja6 » 2017-11-09 @ 23:06
cyclone3d wrote:Well, if it has the stock motherboard and CPU, it is an Intel 440BX based Slot 1 motherboard with a Pentium III 650Mhz CPU.
The only pic I have that could be helpful is https://cdn.discordapp.com/attachments/ ... 20_hdr.jpg
The CD rom is connected to secondary IDE on the motherboard while the HDD is on primary. I'm not sure how much o f a difference it would make
andreja6
Postby yawetaG » 2017-11-10 @ 07:43
Step 1: Remove all hardware (add-in cards) that isn't required for a clean installation of Windows 98. Try again.
Step 2: Take better pictures.
Unfortunately Gateway screwed up their site some time ago, so searching for models not listed on the support pages doesn't work anymore because the search doesn't work. If you can somehow access the right page via Google, it's likely you can still download drivers and manuals.
yawetaG
Postby oeuvre » 2017-11-10 @ 13:23
Most definitely a 440BX chipset.
HP EliteBook 840 G3
i7 6700K, 32GB, NVIDIA GTX 1060, 256GB M.2 SSD + HD, Windows 10
User avatar
oeuvre
Postby AlaricD » 2017-11-13 @ 15:32
andreja6 wrote:The CD rom is connected to secondary IDE on the motherboard while the HDD is on primary. I'm not sure how much o f a difference it would make
Definitely the CD-ROM should still be detected if you used it to install Win9x, since it's on the secondary (even on tertiary and quaternary controllers, so long as they're on the right port and interrupts). It won't, however, if you've got the (!) on your hard disk controllers or often if they're just showing up as a "standard" IDE controller.
Renaming the CONFIG.SYS and AUTOEXEC.BAT (I reverse extensions for non-palindromes, and invert the palindrome extensions, so .BAT becomes .TAB, .COM becomes .MOC; .INI becomes .NIN, .SYS becomes .YSY and so on) will eliminate DOS drivers as being the problem.
I'm also loath to use "cable select", rather I jumper the drives to match their intended status and make sure I put them on their correct spot on the cable, but probably that's not too huge a concern if a DOS driver detects the drive.
User avatar
AlaricD
Postby candle_86 » 2017-11-13 @ 16:18
is a standard 440bx board, same one in the GP-400 I had for awhile, nothing overly special about these things, mine had a Rage 128 All In Wonder and 128mb of ram
I7 950 - Intel DX58SO - GTX 950 - 12gb DDR3 1333 - 250gb SSD - Windows 10 Pro
Pentium 4 3000 - Abit IC7-G - 6800GT - 2gb DDR500 - 500gb SATA - Windows XP Home
Sempron 2500 - ECS KT600A - Ti 4200 - 512mb PC-100 - 80gb IDE - Windows ME
User avatar
candle_86
Postby cj_reha » 2017-11-13 @ 17:08
I've got two of these Gateway systems, both P3 Katmais, one 450 and the other 500 mhz. I was fortunate enough to be able to identify the parts myself and was able to get non OEM drivers that worked just fine.
User avatar
cj_reha
Postby chinny22 » 2017-11-17 @ 15:23
Could simply be the drive is dead.
If you have another IDE drive (CD/HDD/whatever) try that.
You can also try setting the jumper on the back of the CD drive to slave and adding it to the other connector on the same cable as the HDD as we know that works fine.
Windows should simply find the drive, no drivers needed.
User avatar
chinny22
Postby AlaricD » 2017-11-21 @ 17:31
chinny22 wrote:Could simply be the drive is dead.
If the drive was *just used* to install Win98, then surely there's a boot disk that was used to access the drive for the installation.
Boot from that diskette and see if it's found in DOS. If it's dead, it'll be dead in both environments, not just one environment.
User avatar
AlaricD
Return to General Old Hardware
Who is online
Users browsing this forum: Baidu [Spider], cskamacska, matze79, OldCat, Srandista and 12 guests
