Mister Xiado wrote:Bake it at low temperature in the oven. At the "warm" setting, if that's an option. Don't want to melt any plastic, just be hot enough to make the water evaporate into the much dryer air around it. Not an option? If it wasn't the ass end of the year, I'd say leave it in the car with the windows barely cracked. That'll heat it right up on a sunny day.
If one must, then I guess some 30c/86f is a perfect temperature.... 😀
There is just this thing of me not doing that, because you know, lead solder and places were food is prepared.
It's the same with the dishwasher... No hardware is going in my machine. I put forks, spoons and plates in it.
gdjacobs wrote:brostenen wrote:Give that PSU a go, when it is dry and all that. Take it apart first, give it a good rinse under the shower (if you have not done that allready), and let it dry on the radiator/heater for some 48 hours. Turn it on outside in the open.
For the rest of the parts, then do the same. Take everything apart, take out any socketed chips, give a good rinse under the shower and let it dry for 48 hours the same way. I think it is much safer and more gentle on the hardware, than sticking it in the oven.
You can connect via an RCD or GFCI plug to reduce your risk.
Had to google, as I did not know what they are. Yes. That's an option, if they are things to protect the rest of the internal wirings in the house. Personally I do not really see why it is a problem, dismantling the PSU, drying it out, and taking a long cable to test in the back yard. As long as stuff has been inspected, bad caps replaced and just making the psu run a testrun for some 25/30 minutes to see if it is stable. If it blows, then I guess the fuses will go as well. Unless of course the house is not protected with fuses and what we in denmark call and "HFI/HPFI" relay.
This... (On Danish, yet you get the general idea on what it's for)
https://da.wikipedia.org/wiki/Fejlstr%C3%B8msafbryder
It is normally mounted right before the fuses, and if one fuse go, this thing will trip and shut down the entire house in one go. 😜
If you install lamps, the power is on, and you short out the 220volt installation. This thing will trip as well, saving lives.
Yeah.... I have tripped these things a lot. Just by getting 220 volt shock, from installing lamps and not caring about shock. 😁
