First post, by Ozzuneoj
Okay guys, sound cards and video cards seem to get a ton of attention around here, but what about hard drives? In some cases, a CF to IDE adapter is nice, but in a lot of cases I love the sound of a hard drive doing its thing and I think the farther you go back in time, the more interesting it gets. Watching the activity light blink and hearing "kzzz kzz kzzzzz" from your floppy drive then seeing the HD activity light blink and hearing "chunk chunk chunk" as that little bit of data is written... awesome. 😀
So, lets use this thread to showcase some interesting things about these incredible mechanical marvels, some tidbits of useful information for working with them, good websites to go for references... and yes, you can post pictures of your collections as well. 😉
I've been going through my huge hard drive collection to sort out the good drives from the bad over the past few days. I'm surprised how many of my old Quantum Fireball drives still have 100% health in SMART and pass the short self test with no issues. I have a couple of Bigfoot drives as well... a 2.1GB that my brother purchased back in the late 90s which has hundreds of bad sectors (among other problems) and a 6GB that has a few bad sectors but still has 90% health in SMART.
I am running into a few older drives that don't seem to work at all on the system I'm using for testing however. I'm using a Dell Dimension 4500S slim desktop from 2002 for efficiency and XP compatibility so I can run Hard Disk Sentinel. It has an 845G chipset with an ICH4 southbridge (ATA-100 controller). A Quantum Pro Drive LPS (120MB?) doesn't seem to be detected no matter what I do. Jumper is set to Master (DS) Turning off UDMA in the BIOS doesn't help. I also have a Samsung WN321620A 2.1GB which shows up fine in HD Sentinel, with 100% Health in SMART, but it appears nowhere in Disk Management or in My Computer. Should I try using an older ATA-33 PCI card with these old drives? I have a feeling some of these are also going to lack SMART support, so if I have to test them on an older system with some manufacturer specific DOS testing utilities, I can do that later.
Also, the wording of the jumper selection on the ProDrive was kind of hard to decipher so I found a really nice document that has jumper settings for the entire ProDrive series. Just in case it eventually isn't on Seagate's servers anymore, I'll upload it here.
    prodrive_jumpers.pdf
    113.1 KiB
    68 downloads
Reply 1 of 18, by BitWrangler
Are you putting them on a cable on their own? Some older drives may have trouble negotiating with much newer drives as slaves.
Also I doubt a 120MB drive supports anything above PIO Mode 4, so DMA turned on may confuse it.
Thirdly, where you have to use 2 drives together, sometimes the master needs SP set also.... even if it says you don't need to, it's on there for backwards compatibility.
Then also worth trying the CS if DS doesn't work, which is cable select setting, that should work for a single drive without a CS cable (has a hole punched in it)
I also have seen issues with drives formatted on machines with various size barrier limitations, not reading, or reading as corrupt on later machines without them, due to changes in the block addressing and vice versa. One troublesome one was supposed to be the 32GB barrier on Award BIOSes prior to June 99, which had a 65536 cylinder limit, or some versions tell it, bodged up code for 8GB plus support, that was incompatible with other implementations.
Reply 2 of 18, by Ozzuneoj
This is very good info! Thank you!
I'm testing drives on their own cable, since its more time consuming troubleshooting master\slave settings for drives from different eras. As you said, some just won't work together.
I tried turning UDMA off in the BIOS, but this board is quite limited due to being a Dell. I'll probably go through at the end and test all of the oldest drives on an older system.
Before SMART existed, was there a good reliable way to determine if a drive was in decent condition without doing a massively time consuming surface scan? I have lots of very very old IDE drives and a bunch of MFM drives around. Some of them are tested and "working" but due to the lack of SMART support I can't say if they are reliable or how many bad sectors they have.
Reply 3 of 18, by elianda
Drives with capacities below ~500 MB often do not support HDD auto detection. Modern BIOSes and all USB controllers rely on the fact that the attached drive supports auto detect.
So the drives probably work fine, you just need an older BIOS where you can enter the CHS geometry of the drive.
Youtube Channel
Reply 4 of 18, by BitWrangler
Everything IDE should autodetect, maybe autodetect when introduced in 486 BIOSes used to speak louder and slower for the drives like the IDE ST-225, WHAT.... ARE.... YOU ???
That's a point, slower! Older drives took longer to be ready and report from when the reset signal was triggered, modern drives go "blip" and have reset and are recognised, older drives do "Whirrrrrrr durrrrrrr durrrrrr blip" and there's a timeout on later controllers... there used to be a setting to allow longer timeouts for older drives, probably in the PII Super7 era.
Edit: Have a vague memory of needing to turn off fast POST to allow extra time for older drive detection on some machines.
Reply 5 of 18, by Kubik
I was actually recently thinking about some sort of "sound emulator" of old drives. Just record various sounds into one of those cheap Chinese sound player modules, add an Arduino to trigger proper sound at proper time...
I never got past the idea, and didn't really do any checks of IDE timing. I'm somehow hoping that without any additional hardware, Arduino itself could handle at least basic PIO modes.
Reply 6 of 18, by elianda
You may think so, but it is wrong. Also auto detect is primarily a feature of the hard drive. Auto Detect as a feature in BIOS was introduced in 386 BIOSes.
Youtube Channel
Reply 7 of 18, by DeafPK
That is interesting. I have seen Conner and Quantum drives from the early nineties being detected and reported with their full name and model numbers when being plugged in to a ~96 pentium computer. Does this mean that the BIOS on this system has got a database including most of the common drives released before HDD auto detection? Perhaps my drives aren't as old as I think they are?
The same PC also detects and reports drives released long after its date of manufacture. It failed however to detect the ST-506 with an IDE converter that comes with my 1986 Compaq.
"an occasional fart in their general direction would provide more than enough cooling" —PCBONEZ
Reply 8 of 18, by BitWrangler
Yeah, it's the IDE part of IDE which means it has a microprocessor controller and firmware that knows it's own block mapping then reports a logical version of that to the host, you think your single platter drive has 16 heads? Interesting. So yah, all IDE drives know what they are and can say so. It's not some buzzword for a hard drive it means something, RLL or MFM drives without controllers onboard are obviously not smart enough to do this.
Reply 9 of 18, by bjwil1991
My AMD K6-2/300 detected my Maxtor 6L200P0 HDD with the name and everything, as well as the new Maxtor (Quantum) D740X-6L (6L060J3). The BIOS string always detects the drive, type, etc. My Packard Bell Pack-Mate 28 Plus only shows the size of the drive, as well as the appropriate parameters, but not the drive name, model, and so on. So, in other words, it varies by the motherboard manufacturer and processor (Pentium and higher).
Reply 10 of 18, by Ozzuneoj
I think we had a thread about this in the past year or two. The easiest way to do it would be to attach some kind of circuit to pick up "blinks" from the HD-LED header and then play a sound on a small speaker. Attaching a speaker directly to the pins was also talked about but I can't remember if anyone had actually tried this or not (probably won't work because speakers are AC), and it wouldn't be too authentic. An arduino might be able to decipher the kind of access going on though.
I think its easier to just use a hard drive. 😁
Reply 11 of 18, by Ozzuneoj
Anyone know what it is in an old hard drive that makes a little tiny short buzz sound periodically? Like, the drive is spinning normally, but once in while there's a tiny additional buzz that's a different tone and lasts a fraction of a second. I've had lots of drives do this. Especially older WD Caviar IDE drives from the mid to late 90s. The drives test out okay in smart and even pass full write-read surface scans. It seems like the sounds eventually stop, so its probably just something they do after sitting for many years, but it always struck me as odd that there would be some kind of change in the drive that caused that noise and yet it doesn't seem to have any impact on the drive's operation.
Reply 12 of 18, by Ozzuneoj
Not a lot of love for old drives here eh? 🤣
I have another question, probably a bit easier to answer.
I'm running SMART tests on every drive I have that supports SMART, using Hard Disk Sentinel. I've had some drives with 100% health and performance in SMART, went through an entire Write-Read surface test and passed with ZERO bad or weak sectors... then at the end of the test the SMART status updated to 0% and showed one single Raw Read Error. I had one drive that did this, then when I ran the full write-read test again, it wiped out the raw read error which brought the health back to 100%!?
100% to 0% to 100% just by running some surface scans... I have to say it makes me a little less concerned about SMART attributes and status. What do you guys think? I have dozens of old drives from the 90s, the vast majority of which have 100% health according to SMART. If one has an error that makes the computer say it is basically DEAD, and yet it has no other problems, and then the error goes away completely after the next test, what should I do with the drive? I doubt these will generally be used to store integral information ever again, as the ones I've tested with SMART are within the 400MB to 13GB range. At best they'll be a nice drive for an authentic period-correct retro rig or a DOS test bench. I'll keep some and probably sell a bunch of them.
Reply 13 of 18, by ODwilly
I know people that toss drive after a mere reallocated sector or two, or a few read errors. However in my experience it is not that concerning. Anything important should be on a good backup or two.
Seagate drives in my experience ALWAYS have read errors after a couple years of use. Heck, I retired a 2005 SATA Hitachi 160gb drive with 14k reallocated sectors this year. Didn't trigger smart and had no issues under windows at all, If you are just using a drive to play games or old programs or even just as an OS drive there really is no reason to worry. Drive dies, swap it out.
Reply 14 of 18, by Ozzuneoj
This is sound advice for older computers, for sure. As long as the data isn't integral (or at least has frequent backups) it really shouldn't matter.
I think what's causing me problems with testing these old drives is that many of them don't seem to keep track of bad sectors in the SMART record. I actually just realized this when testing a 100% working drive, only to have a full disk reinitialization find one bad sector. Not bad I thought... but SMART still says the drive was 100%? When I checked the details of SMART on this drive though, it had no entry for sectors at all, only for read errors and some other things.
I have another drive that seems to work fine despite SMART flagging the system BIOS on startup on my test system. At the end of the drive are several bad sectors (lots of them). I know in the old days people would just partition the drive so that this area would be unused. I guess that could work in this case too.
Hard drives a certainly a complicated part of retro computing...
Reply 15 of 18, by BitWrangler
It's probably a thermal recallibration.
The bad sectors thing. They can be "soft" bad sectors, frequently windows used to cause a bad sector when it crashed while writing. Also several common virii used to create bad sectors to hide in. I'm forgetting the name of the util you could use to "low level" format it, in quotes because it wasn't a true low level as used on MFM drives but cleared bad sectors that weren't really bad.
Reply 16 of 18, by SW-SSG
If I'm understanding right, it's a thing I've always attributed to aging ball bearings. A Fujitsu MPE3136AH with ~29,000 power-on hours I use in my 440BX box produces this sound very often. It's not something I've heard out of any newer HDDs with FDB bearings.
Reply 17 of 18, by Matth79
Not just old drives, I remember a whole room full of systems prepared for something - in the Win3.x days before rampant background junk, and they all chattered, a tick tick tick sound from the drives, in glorious octophonic as the machines did it in random order - pretty sure it was thermal calibration as they were warming up.
Reply 18 of 18, by BitWrangler
Can't remember exact drive models now, but there was quite a difference between a Seagate and Quantum I had, think they were around 120 to 150MB models, maybe a medallist and a prodrive... The Seagate would do a fairly quiet and low brrrrrp which you could easily miss if you weren't listening for it... the Quantum on the other hand did a really alarming Snick Snack Snacker Snickwhich no matter how often you heard it, would still have you lunging in panic for the off switch from time to time before you remembered.
