Benchmarking Noob - Few Questions
Discussion about old PC hardware.
Postby Smack2k » 2017-11-23 @ 14:18
Hey all
I have a bunch of random PCI and early (1x / 2x) AGP Video cards (with a few 4x to) from various companies (ATI / S3 / Nvidia / others) that I'd like to benchmark just for the hell of it to see where they fall against each other. I've never gotten into benchmarking in the past so I wanted to know if there were any tips on setting up the system to do the testing? I have boards, procs, memory, etc around but didn't just want to throw anything together without getting some advice. Do I want a proc that is faster / newer than the video cards? Anything in particular about memory / HDD / motherboard? For the tests what are the recommended benchmark apps to test these mid 90s - early 2k cards? Looking to learn a lot more about the ins and outs of the cards along the way as well.
Appreciate the advice as I'd like to get this setup and start testing!
User avatar
Smack2k
Re: Benchmarking Noob - Few Questions
Postby cj_reha » 2017-11-23 @ 15:58
I actually was doing the same thing with one of my Pentium 4 boards. It's the AOPEN AX45-533 U2 with the SiS 645DX chipset, and a "true" AGP Universal slot. It's accepted every old AGP card I've thrown at it even back to really early S3 Virge/ATi Rage 4 MB AGP 1x cards. I even got it to boot with a 1 MB PCI Trident :lol:
A lot of early cards had problems with 3dMark 99 under XP, weird framerates and artifacting, but I expected it. I was just doing it for fun :P
User avatar
cj_reha
Postby vvbee » 2017-11-23 @ 16:08
My tip is for when you report the results. Prefer whole numbers without decimals, unless it's an average of 100+ runs.
User avatar
vvbee
Postby Aideka » 2017-11-23 @ 19:12
The faster the processor, the more it brings out the differences in the cards. I would use a fast Pentium 4 or Athlon system, with universal AGP slot. Sure, it may not be periord correct, but it is a good way to see the real difference between cards.
User avatar
Aideka
Postby Smack2k » 2017-11-23 @ 19:54
Perfect. That is what I wanted to know. Going to use a fast P4 as those differences are exactly what I want to see.
In terms of apps, outside 3dMark versions any other software you'd recommend to get some good results / see the differences in the mid - late 90s PCI and AGP cards?
User avatar
Smack2k
Postby Ampera » 2017-11-24 @ 04:23
Half-Life at high resolutions, as it was a high profile game.
If you can get a REALLY fast CPU, run a test of Doom, could be interesting to see how 2D performance has held up with these cards.
Stress 32-bit colours if possible. This was a thing that some cards couldn't even do in the late 90's, but extra points for good 32bpp colour performance.
User avatar
Ampera
Postby gandhig » 2017-11-24 @ 07:42
Final Reality.
User avatar
gandhig
Postby Smack2k » 2017-11-24 @ 11:35
Ampera wrote:Half-Life at high resolutions, as it was a high profile game.
What would you consider a "really fast" CPU?
I am looking at a mid 2 GHZ Athlon XP or a 3.2 GZ P4 (If I can find the right heatsink for it) for the proc...
OS Wise, XP OK to run as the OS?
User avatar
Smack2k
Postby clueless1 » 2017-11-24 @ 12:04
Smack2k wrote:Perfect. That is what I wanted to know. Going to use a fast P4 as those differences are exactly what I want to see.
Just keep in mind that those results won't necessarily translate to a period correct system. So if you're ever building a system down the road, you still want to benchmark the cards you're deciding between in that system.
For example: On the fast system, card A is 30% faster than card B. But in a period correct system, their performance is nearly identical. Without that knowledge, you may pick card A for the period correct system. With that knowledge, you might decide to use card B in the period correct system and save card A for a faster system.
User avatar
clueless1
Postby Smack2k » 2017-11-24 @ 14:12
My goal really is to benchmark a lot of lesser used / not as popular cards, PCI versions of more known AGP Cards, and other cards that you'd really only want to use if you didn't have a better option or weren't looking to spend more on the premium card but still get some decent gameplay with what you have. Seen so many benchmarks of more popular known high end cards but not as much for the "little guys". Just a side project I have been thinking to do for a while and now that I am out of room to put anymore retro machines in my retro cave, this was my next venture....so wanting to get the best overall testbed to use for mid 90s - early 2ks (01-02) cards of this nature for both 2D and 3D stats...
My big question would be what would be best apps to use? Would DOS benchmarking be better or Windows? This where my benchmarking noon comes out as I am not sure
For 2D benchmarking I can only currently find XP or newer apps and nothing older on Windows sids
User avatar
Smack2k
Postby clueless1 » 2017-11-24 @ 15:49
DOS benchmarks for DOS era hardware; Windows benchmarks for Win era hardware. DOS benchmarks tend to reveal hardware-level performance while Win benchmarks can vary wildly by driver version. No drivers in DOS.
2D benchmarks for Win9x:
Ziff-Davis Winbench
Tom's 2D (tomshardware made a 2D windows benchmark back in the day)
PCMark (https://www.futuremark.com/benchmarks/legacy)
ATTO and Diskspeed (https://www.philscomputerlab.com/hdd-benchmarks.html)
Phil's DOS benchmark pack (https://www.philscomputerlab.com/dos-be ... -pack.html)
EDIT: just found this post with a couple of nice links:
viewtopic.php?t=37982
User avatar
clueless1
Postby Smack2k » 2017-11-25 @ 12:50
Thanks a ton!! Gonna get my test bench setup and get to work!
User avatar
Smack2k
Postby Deksor » 2017-11-25 @ 13:52
You can still increase DOS benchmark results on AGP cards to some degree with Slot 1 boards and Super socket 7 IIRC
Deksor
Postby kva » 2017-11-25 @ 14:44
Just remember to do at least three runs of every benchmark on every card and present the average value.
kva
Postby Smack2k » 2017-11-27 @ 11:35
Deksor wrote:You can still increase DOS benchmark results on AGP cards to some degree with Slot 1 boards and Super socket 7 IIRC
Going to be running these all from one board as my base....with a P4 processor. Just trying to figure out what the best speed proc to use as I have a few different ones.
Once that is done, I can look into doing other boards and focus in on certain types. Just want to get a base down for all the cards from one source first.
User avatar
Smack2k
Return to General Old Hardware
Who is online
Users browsing this forum: Baoran, harddrivespin, IanB, jarreboum, lolo799, Unknown_K and 8 guests
