Need Help Identifying This Add-On Card for a 286
Postby tegrady » 2017-11-25 @ 15:57
Hi, I just ran across an auction for this item.
I cannot figure out what it is though. The box calls it "Add-On Card for '88 '286 Personal Computer". The card itself says "CK-1" and C/N 800310. The main chip is UM82C8167 and it has an onboard battery. There is no i/o port on it.
Here are the photos. Any idea what this is?
Thanks.
User avatar
tegrady
Re: Need Help Identifying This Add-On Card for a 286
Postby Arkady » 2017-11-25 @ 16:05
It's a clock/calendar card for IBM PC/XT and compatibles.
With a bit of luck, you will be able to set time and date with the MS-DOS commands or you will need a specific driver.
User avatar
Arkady
Postby jesolo » 2017-11-25 @ 16:07
Just to add to the above.
Older PC's didn't come with real time clocks so when you shut down and restarted the PC, you had to enter the date and time again.
This card kept the date and time settings and was loaded via a driver upon start up.
User avatar
jesolo
Postby tegrady » 2017-11-25 @ 17:07
Thanks for the info! Sounds like I have no use for this card...
User avatar
tegrady
Postby Ozzuneoj » 2017-11-25 @ 17:34
A lot of times add-on boards would have multiple functions, including an RTC like this. I'm not sure when PCs started having them built into the motherboard as standard, but my IBM 5150 has an AST SixPak Plus that has provides 384K memory expansion, RTC, serial, parallel and a gameport on one board. Having just a single tiny card just for the RTC alone doesn't seem like a terribly interesting use of limited ISA slots in older boards.
Time Machine = FIC PA-2013 2.1 - K6-2 500 - 256MB PC-100 - TNT2 Pro 16MB AGP - Labway Yamaha YMF719-E - Midiman MM401
Amibay For Sale Threads
I have lots of PC stuff for sale on Mercari! Get a $10 sign up credit with invite code VBGQMM.
User avatar
Ozzuneoj
Postby Zup » 2017-11-25 @ 17:44
RTC was made standard with XTs, so they could keep HDD and floppy configuration.
Multi I/O was standard with Pentium 2 (maybe MMX?). Before that, only few morherboards had integrated IDE/floppy/com ports. Through 286/386/486 and Pentium, I've seen computers with integrated ports, but it was not usual.
Gameports were usually a sound card thing, so they got integrated at the same time (Pentium MMX?).
I'm selling some stuff!
User avatar
Zup
Who is online
Users browsing this forum: Cyrix200+, DonutKing, Google [Bot], knowledge [bot], luckybob and 9 guests
