Any of these 486 boards worth buying?
Discussion about old PC hardware.
Postby ElectroMan » 2017-11-29 @ 10:33
ElectroMan
Re: Any of these 486 boards worth buying?
Postby derSammler » 2017-11-29 @ 10:45
For $5, every 486 board is worth buying. The sram cache chips alone are worth that much.
derSammler
Postby tikoellner » 2017-11-29 @ 10:59
Yep, 5$ is always a good deal.
I personally avoid:
- Opti based 486 boards;
- PCI 486 boards (just my personal preference, I just think a proper 486 is VLB or ISA only);
- Barrel battery - but if there was no leak AT ALL, I would make an exception.
I also hate if there are any unused spaces on the board - as those on the first two boards.
I think the last one is the best: SIS, VLB, double cache-banks, 3.3v support (I see the voltage regulator). The only donwside: the battery. I'm not sure if it didn't leaked already.
User avatar
tikoellner
Postby clueless1 » 2017-11-29 @ 11:25
Um...for $5 each, I'd scoop them all up before someone else grabs them, then figure out which are best. You'd normally be hardpressed to get one board for $20.
User avatar
clueless1
Postby Kubik » 2017-11-29 @ 11:37
I wouldn't even think about it and buy all of them. Untested 486s normally sell on eBay for 20 or more.
Kubik
Postby amadeus777999 » 2017-11-29 @ 11:58
Buy it - you can sort them out later.
The board with a 496/97 chipset is most likely the winner here(fast + PCI bus).
User avatar
amadeus777999
Postby Mut » 2017-11-29 @ 15:31
I liked the second motherboard, does someone have ever seen this NIHT chipset? If this is somekind of of obscure chipset a benchmark would be very interesting.
Mut
Postby Kubik » 2017-11-29 @ 15:54
You mean HiNT chipset? I see them now and then, they're not too rare.
Kubik
Postby BSA Starfire » 2017-11-29 @ 16:43
At that price I'd buy them all no question.
386SX 33MHz,4MB Ram,ALi M1217 motherboard,OAK OTI077 1MB. Seagate ST1144A.
386DX 25MHz,IIT 387,8MB RAM,Opti,32K cache,WDC90C30 512K.Conner CF170A.
IDT Winchip C6 200MHz,DFi P5BTX/L,Number Nine S3 ViRGE 2MB,SoundBlasterCT2260,1.2Gb Fujitsu.
User avatar
BSA Starfire
Postby ElectroMan » 2017-11-29 @ 18:35
ElectroMan
Postby BeginnerGuy » 2017-11-29 @ 18:47
mmm did you get them all?
My favorite out of the pack is the sis871 VLB for a build, though the old battery needs to be removed pronto. I'm also in the party of preferring a Pentium over a PCI 486 board but for $5 it's a steal. All of those boards can be resold for a profit if you buy for $5.
Sup. I like computers. Are you a computer?
User avatar
BeginnerGuy
Return to General Old Hardware
Who is online
Users browsing this forum: BinaryDemon, BLEXBot [Bot], Deksor, Xicor and 5 guests
