trobuleshooting dead ps2 + serial ports
Discussion about old PC hardware.
Re: trobuleshooting dead ps2 + serial ports
Postby Jepael » 2017-12-09 @ 21:33
chrisNova777: What are you trying to do with the serial ports that does not work? I mean, how have you tested if they are broken or not? Does a serial mouse work, or have you tried a loopback test with a terminal program?
The thing is, the dongle might be too power hungry compared to a serial mouse and draw too much current from that RS232 level converter that is on the motherboard, it's a charge-pump based voltage doubler/inverter.
Jepael
Postby Auzner » 2017-12-16 @ 02:41
What dongle is it?
It maybe was incompatible levels and damaged the winbond?
Also the auth of that age seems reversible...
User avatar
Auzner
Previous
Return to General Old Hardware
Who is online
Users browsing this forum: BLEXBot [Bot], dickkickem, FluffyBunnyFeet, Thermalwrong and 13 guests
