pentium 3 isa psu ?
Re: pentium 3 isa psu ?
Postby gdjacobs » 2017-12-03 @ 23:33
Alrighty. Computer PSUs supply power at different voltages, as you know. Modern computers consume most of their power supplied at 12V and modern PSUs are therefore designed to supply the majority of power via the 12V wires. Older computers consumed more power at 3.3 and 5V with 12V not having to be quite so strong. Athlon and Athlon XP systems in some circumstances required over 30A supplied via the 5V ATX pins, but this often is too much for modern power supplies.
The supply option you're looking at should be fine for a P3 or older (and probably for a P4 as well), but you will likely run into problems with an Athlon or Athlon XP.
User avatar
gdjacobs
Postby scroeffie » 2017-12-04 @ 09:34
https://www.alternate.nl/Corsair/VS-Ser ... =7&lk=9533 Corsair VS Series VS350
https://www.alternate.nl/Corsair/VS-Ser ... =7&lk=9533 450
https://www.alternate.nl/Cooler-Master/ ... -(ErP-2013)-400W-Green-power-supply-400-Watt-voeding/html/product/1316447?tk=7&lk=9533 +3,3 V 20 A
+5 V 20 A
+5 Vsb 2.5 A
-12 V 0.3 A
+12 V gezamelijk 30 A
+12 V1 30 A
scroeffie
Postby scroeffie » 2017-12-04 @ 10:50
scroeffie
Postby gdjacobs » 2017-12-04 @ 14:42
These supplies you're posting are all fine. I just wanted to advise you of the potential limitation prior to your final decision.
User avatar
gdjacobs
Postby scroeffie » 2017-12-04 @ 15:34
original psu is no brand 235 watt / +3.3v 12A / +5v 18A / +12v 8A / +5vsb 1A / -5v 0.5A / -12v 0.5A
Seasonic S12II Series 520 watt/ +3.3V 24 A / +5V 24 A/ +12V1 20 A / +12V2 20 A / -12V 0.8 A / +5VSB 2.5 A
pentium 3 800mhz /1hdd/1cd rom/1 floppy/2 videocards i think i have a voodoo 2 voodoo 3 and some other cards
and 1 fan thats it
scroeffie
Postby gdjacobs » 2017-12-04 @ 23:20
Yeah, P3s don't draw that much juice.
User avatar
gdjacobs
Postby scroeffie » 2017-12-05 @ 17:08
i just found out i dont have a awe soundcard 32 but just a normal sounblaster 32 ? it as 2 ram sticks and the card is very long
scroeffie
Previous
Who is online
Users browsing this forum: andrea, DandumontP, Mister Xiado, Tiido, VooDooMan, xjas and 11 guests
