20pin atx connector to 24pin motherboard
Discussion about old PC hardware.
Postby 386SX » 2017-12-05 @ 18:51
Hi,
I'm trying some different 20pin power supply on a 24pin motherboard (supporting dual core intel / ddr2) leaving the last 4 pin of the mobo connector obviously open. I read somewhere that beside some heavy power requirements it should still boot so I used a 1,65ghz low power dual core cpu but no way, the fan seems to move a bit and then it stops.
Do you think I still need a 24pin power supply or I can use these P4 20pin ones anyway? Or I need the converter cable?
Thank
386SX
Re: 20pin atx connector to 24pin motherboard
Postby LR35902 » 2017-12-05 @ 19:05
Just to be sure, is there a 4 pin cpu power connector on the board?
User avatar
LR35902
Postby 386SX » 2017-12-05 @ 20:07
LR35902 wrote:Just to be sure, is there a 4 pin cpu power connector on the board?
On the mobo there's the usual 24pin atx connector and separately the 4 pin 12v connector too. ;)
386SX
Postby havli » 2017-12-05 @ 20:14
Yes, 20pin will work just fine.
User avatar
havli
Postby 386SX » 2017-12-05 @ 20:18
havli wrote:Yes, 20pin will work just fine.
This make me think something is wrong with the mobo cause there's no way. I tried also a powerful Enermax 20pin for Athlon XPs.
386SX
Postby 386SX » 2017-12-06 @ 10:48
It looks like there's something wrong with the board a MSI MS-7525 on socket 775. With a 24pin power supply it still can't boot. The fan move a bit and then stop.
386SX
Postby .legaCy » 2017-12-06 @ 12:25
The 4 pin power connector that sits right next to the cpu is connected right?
Just to be sure that is connected properly you can wiggle it in a little bit.
Is there anything that may cause short circuits like those metal stand offs in the case?
User avatar
.legaCy
Postby 386SX » 2017-12-06 @ 16:08
.legaCy wrote:The 4 pin power connector that sits right next to the cpu is connected right?
The connector is stable and the mobo is outside the case with just the cpu and ram. Maybe some components failed and causing this?
386SX
Postby SW-SSG » 2017-12-06 @ 18:11
It does sound like something on the board is shorted.
Without the 4-pin ATX12V attached, it should power on (fans spinning and etc) but not POST... at least in my experience.
[ThinkPad A30] PIII-M 1133MHz, 256MB PC-133, 30GB 4200RPM, ATI R7000 16MB, 15" 1024x768px, WinXP Pro+Win98SE
User avatar
SW-SSG
Postby .legaCy » 2017-12-06 @ 19:26
Well maybe failing mosfets or mosfet drivers, if you can diagnose the vrm part of the board.
This happened to me twice, one was a shorted motherboard(thankfully the psu protection prevented the motherboard to be fried, removing the short brought it back) and other was bad fets on the board.
User avatar
.legaCy
Return to General Old Hardware
Who is online
Users browsing this forum: BloodyCactus, fitzpatr, Ozzuneoj, W Gruffydd and 5 guests
