First post, by .legaCy
- Oldbie
Hi i finished my 486 build(soon i will post the details of the build on the correct section) everything seems to work fine, all the case switches and LED are working(i even configured to turbo enabled to be fast and disabled to be slow) but my pc speaker don't sound at all.
I tried:
- continuity tests on the cables and the conector(seems ok)
-changing the speaker itself (seems ok)
i'm thinking that maybe the motherboard can't produce the signal strong enough to drive the cone.
Maybe if i use the piezo beeper speaker that usualy came with more modern motherboards?
What do you guys think?
