First post, by alexjlopez
Does anyone have any experience with this board (M5ALA v1.0)?
Specifically, I was wondering if the board will support K6-2+/K6-3+ processors. Also, I haven't had any luck finding drivers/firmware or documentation specific to version 1.0.
Any help would be appreciated. Thanks!
Reply 1 of 2, by gdjacobs
If it can handle BIOS version ALA1105B, you should be fine. Patched version below:
http://wims.rainbow-software.org/index.php?start=40&count=30
Beyond the firmware, you just need to use a low enough vcore, ideally 2.0v.
