First post, by PKFreeZZy
Originally I was gonna buy a 40mm fan for my current CPU, a 350Mhz Pentium II, but when I saw the surprise delivery charge just as I was about to buy it I backed off.
I ended up buying a Pentium III EB on eBay with a clock speed of 600Mhz and 133Mhz FSB which comes with a fan and a heatsink as well.
My current worries are all related to the FSB. I read that the EB models run on 133Mhz while my MoBo only guarantees work at 100. It does have jumper settings to enable higher FSB speeds but as the manual reads, they're not recommended. However, it supports multipliers up to 8.0x
Will it work fine at 100Mhz FSB with a 6.0x multiplier?
My Windows 98 PC: Slot 1 Pentium III 600 (Katmai) | 256MB PC133 SDRAM | 64MB Leadtek WinFast GeForce2 Pro | Creative SB16 CT2230 | Intel PRO/100+ with Alert on LAN* | 18.64GB Seagate ST320011A | Corsair CX430 | ASUS P2B Rev. 1.04
Reply 2 of 12, by PKFreeZZy
By GeForce, do you mean the GeForce 256 or the series in its entirety? I'm planning to use a GeForce2 MX400 with it.
Reply 3 of 12, by dionb
Exactly which i440BX board do you have? And which RAM?
The BX was famous for being able to overclock well past 100MHz, frequently up to and beyond 133MHz, but you have a few dependencies:
- the Coppermine (E-series Pentium 3) CPU runs at 1.65V-1.75V (depending on CPU), which is a lower voltage than the old Katmai P3 and Deschutes P2 CPUs (~2V) . Only later BX boards support Coppermine voltages.
- To get the CPU to work well, it needs BIOS support. So you need a board with Coppermine support in BIOS (or an update that offers this)
If you have these, the CPU will definitely work, worst case at 100MHz FSB, so with its 4.5x multiplier it will run at 450MHz
To reach 133MHz FSB and 600MHz CPU clock, you also need:
- RAM runs at full FSB speed on the BX, so your RAM needs to handle the higher speeds too. If it's PC133 you should be OK. Some PC100 will overclock to 133MHz, but not all.
- The BX only supports 2/3 AGP dividers, so at 133MHz you'll also be overclocking the AGP bus to 89MHz. As stated, AGP speeds aren't usually a problem, but if you hit trouble, try a different video card.
- The BX chipset itself does support a 1/4 PCI divider, which allows the PCI bus to stay at 33MHz when you overclock the FSB to 133MHz, but not all boards implement it. If not, you'll be running the PCI bus at 44MHz. That is pretty fast and will probably cause problems. RAID and SATA cards are particularly sensitive to high PCI clocks. If you can't get a 1/4 divider on your board, be prepared to run that CPU at less than 133MHz FSB (or get a different BX board that does).
Reply 4 of 12, by kaputnik
Haven't tried anything newer than a Ti4800 in a 440BX mobo, but in my experience anything Geforce up to that works just fine at 89MHz AGP.
The problem is that the 440BX only offers 1/1 and 2/3 AGP dividers, which means the AGP bus will run overclocked at 89 MHz at 133 MHz FSB speed (133 * 2/3 = 89). Specced speed is 66MHz. The Geforce series generally handles this really well, even managed to run my Ti4600 at 100MHz AGP for months without a hitch before discovering my mistake 😁
The 440BX itself is a very good overclocker. If the mobo got the 133MHz FSB option, you're almost guaranteed the chipset itself won't give you any problems.
Reply 5 of 12, by PKFreeZZy
The Motherboard is a P2B from ASUS, I just hope it'll work. Pretty sure all 3 of my RAM modules are capable of running at 133Mhz, confirmed by CPU-Z.
I ordered the EB version of the Coppermine architecture, am I done for?
Reply 6 of 12, by dionb
I didn't say "exactly" for nothing - there are quite a few revisions of the P2B 😉
Fortunately it's one of the best documented boards of its era, so if you can check which version it is, this site will tell you what will work with it:
http://homepage.hispeed.ch/rscheidegger/p2b_p … ficial_upgrades
Reply 7 of 12, by PKFreeZZy
I just checked everywhere, on the board and in CPU-Z, there's no letter in the name, just a plain P2B Revision 1.02 with the C1 revision of the BX chipset.
Reply 8 of 12, by meljor
Look at that link, it will tell you all you need to know.
In short: wrong revision board so it will not work.
Reply 9 of 12, by Skyscraper
The good and informative link dosn't tell you all there is to know about the P2B + Coppermine CPUs but in ths case enough and meljor is right, it wont work without doing a "pin-mod" on the CPU edge connector.
Long version...
Rev 1.02 is the very first revision of the vanilla P2B. It should have the correct PCI-divider for operation at 133 MHz FSB (my 1.02 at least does) and it should be stable at 89 MHz AGP clock with most video cards (my board at least is). It does not support voltages below 1.8V so if you want to run a Coppermine CPU regardless of FSB you need a FC-PGA Coppermne and a FC-PGA ---> Slot-1 Slotket with VID selecton. Jumper the Slotket for 1.8V and update the BIOS and it "should" work fine. If your CPU is Slot-1 (and I guess it is?') it will "probably" not work without modification (isolation and/or shorting of VID pins on the CPU edge connector).
Disclamer: Your milage may vary...
Reply 10 of 12, by PKFreeZZy
...ok
Can I even underclock the thing to run at 100Mhz FSB or is the overvoltage too much for the board?
And yes, it's a Slot 1 P3.
Reply 11 of 12, by Skyscraper
PKFreeZZy wrote:
...ok
The issue is that the CPU will ask the board to provide 1.65 or 1.7V and the motherboard do not support those voltages and will probably provide 0V.
Should the motherboard for some reason provide the minimum 1.8V then thats fine and it will work. The issue isnt that 1.8V is too much, the issue is getting the motherboard to understand that it should provide said 1.8V. It can be solved by a CPU VID pin mod but it's not super easy.
Reply 12 of 12, by PKFreeZZy
I guess I'll try that once I've gathered enough courage.
