Reply 21 of 151, by .legaCy
My thoughts on this vulnerability:i really don't care too much,it is like the wifi exploit that was revealed not too long ago, for me it is just a threat to servers and corporate environment.
about cloud services, oh well if you use it, you are giving up all your privacy.
The right thing that intel could do is fix the bug and recall the current gen Xeon cpu and provide a discount to last gen consumer cpu to upgrade to a new bugfree generation.
Reply 22 of 151, by Baoran
Passwords are one thing I might be worried about. There are people who actually pay decent amount for password lists that have been created using malware infected home pcs. If they get access to your e-mail account, they pretty much get access to all the accounts that you used the e-mail account with.
Reply 23 of 151, by gerwin
Scali wrote:
Intel put up a list of affected CPUs here: https://security-center.intel.com/advisory.as … anguageid=en-fr
Apparently anything up to and including the Core2 is unaffected. Things seem to have been introduced with the first Core i7.
I figure that is because they did not bother to list older CPUs.
The way intel writes responses to this issue, it is like a press commentary: deny it is intel's fault, deny the full scope of problems, emphasize that intel is fully comitted to ensure security.
Reply 24 of 151, by dr_st
This is the dumbest thread in the history of the universe.
A bunch of people with no clue and no ability to grasp the technical details compete with each other on who will spread more FUD garbage. And the few folks, who actually can understand the details, tag along for the fun of it.
Reply 25 of 151, by meljor
You just described life in general..
Reply 27 of 151, by Falcosoft
A Powershell script is available that can help to determine what CPUs are affected according to MS.
http://mikefrobbins.com/2018/01/04/using-powe … 7-5715-spectre/
The most relevant line considering the meltdown vulnerability is:
Hardware requires kernel VA shadowing: xxx
On a patched affected Intel system the result is:
 PS C:\WINDOWS\system32> Get-SpeculationControlSettings
Speculation control settings for CVE-2017-5715 [branch target injection]
Hardware support for branch target injection mitigation is present: True
Windows OS support for branch target injection mitigation is present: True
Windows OS support for branch target injection mitigation is enabled: True
Speculation control settings for CVE-2017-5754 [rogue data cache load]
Hardware requires kernel VA shadowing: True
Windows OS support for kernel VA shadow is present: True
Windows OS support for kernel VA shadow is enabled: True
Windows OS support for PCID optimization is enabled: True
BTIHardwarePresent : True
BTIWindowsSupportPresent : True
BTIWindowsSupportEnabled : True
BTIDisabledBySystemPolicy : False
BTIDisabledByNoHardwareSupport : False
KVAShadowRequired : True
KVAShadowWindowsSupportPresent : True
KVAShadowWindowsSupportEnabled : True
KVAShadowPcidEnabled : True
On a non-patched (meltdown) unaffected AMD system the result is:
PS C:\Windows\system32> Get-SpeculationControlSettings
Hardware support for branch target injection mitigation is present: False
Windows OS support for branch target injection mitigation is present: False
Windows OS support for branch target injection mitigation is enabled: False
Hardware requires kernel VA shadowing: False
Suggested actions
* Install BIOS/firmware update provided by your device OEM that enables hardware support for the branch target injection mitigation.
* Install the latest available updates for Windows with support for speculation control mitigations.
BTIHardwarePresent : False
BTIWindowsSupportPresent : False
BTIWindowsSupportEnabled : False
KVAShadowRequired : False
KVAShadowWindowsSupportPresent : False
KVAShadowWindowsSupportEnabled : False
KVAShadowPcidEnabled : False
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 28 of 151, by Azarien
The facts are:
- Meltdown is a vulnerability allowing ordinary programs to read kernel memory, something that the CPU is supposed to protect against. It's Intel's fault, not OS developers'.
- Intel released a list that basically says "everything since the first i3/5/7 is affected". The list does not include Core 2 and earlier processors. This may mean that they are not affected or that Intel just didn't bother to include older chips on their list.
- AMD is convinced their CPUs are not affected.
- There are already security patches for Windows 10 and Linux.
- At least on Linux, this patch has a significant performance cost. On Core 2 and earlier chips that penalty is even higher (because of lack of PCID support). This should be true for Windows too, theoretically.
- As of today, the Linux patch (with its performance cost) enables itself automatically on all non-AMD x86/x64 CPUs. It can be force disabled.
I don't know if the Windows patch checks the CPU for vulnerability or is just permanently enabled.
I wouldn't worry about the vulnerability itself. It is already fixed, and sooner or later the fixes will become non-optional in their respective OSes.
For old OSes - who cares.
I worry about sudden slowdown of most of PCs in existence, especially older ones, some of which perhaps unnecessarily.
Reply 29 of 151, by Scali
That is a bit too generalized, and sounds like there is a bug in the CPU in the protection, and programs can actually read kernel memory via the CPU.
That is not correct.
What happens is that because we know that Intel CPUs perform speculative execution in a way that caches data before the access to that data is determined, a side-channel opens up: We can time access to a certain memory location, to see if it was cached or not.
With carefully crafted code, you can time access to pieces of memory, so that you can see whether it was cached or not.
You can't actually access the data, but the timing will tell you whether it was cached or not.
You can take this further by doing bitwise comparisons...
if (x & 1)
a();
else
b();
By timing this, you can infer individual bits in the variable, reconstructing the entire data.
The original paper claims they can read memory at about 503 KB/s: https://meltdownattack.com/meltdown.pdf
So it's not really the protection failing. It's a side-channel, which is also why it exists on so many CPUs, also ARM and POWER for example. Not because they all happen to have the exact same 'bug', but because they all have similar performance optimizations deep inside the core, and someone figured out that you can use this as a side-channel. Intel and other vendors can however modify future CPUs to remove the side-channel.
Reply 30 of 151, by amadeus777999
Scali wrote:
That is a bit too generalized, and sounds like there is a bug in the CPU in the protection, and programs can actually read kerne […]
if (x & 1)
a();
else
b();
Pretty fascinating.
Reply 31 of 151, by Baoran
There are patches to other windows versions too and not just windows 10. I still use windows 7 in my main pc and I downloaded KB4056894 security patch that is suppose to do similar fixes to windows 7. It might mess up your antivirus software if your antivirus software hasn't been patched to be compatible with it.
Azarien wrote:
The facts are: […]
The facts are:
Reply 32 of 151, by .legaCy
Well it is 2018, everyone should be using two factor authentication on relevant services, my relevant email accounts, my bank account and my steam account uses 2 factor authentication, nowadays most of the time getting just the password isn't a big deal.
Reply 33 of 151, by Auzner
Quoting for good high level
That huge!? I expect royalties from the book and film deals to ensue.
Reply 34 of 151, by idspispopd
MiniBits wrote:
Time to put 486's into production again, I am sure die shrinks and such can up the speed on those quite a lot 😁 and new 486 mobs! woooo
Intel's Quark SoC is based on the 486 with some additions from Pentium, but no branch prediction, superscalar execution etc.
Should be safe from these bugs.
Reply 35 of 151, by Azarien
Falcosoft wrote:
A Powershell script is available that can help to determine what CPUs are affected according to MS. http://mikefrobbins.com/2018 […]
Has anyone tried this on a Core 2 or earlier PC?
Reply 36 of 151, by bjwil1991
No wonder my Packard Bell Pack-Mate 28 Plus is faster than my laptops that have the Pentium 4 or higher.
Reply 37 of 151, by Azarien
The script itself requires PowerShell 3.0, which means Windows 7 or higher is required to run it.
I've just tested two semi-old PCs (will add more if I have opportunity):
— Atom N570, 1.66 GHz: False
— Pentium Dual-Core T4200, 2.0 GHz: True
Reply 38 of 151, by KT7AGuy
I just ran the script on my unpatched Win7 Pro machine with a Phenom II X2 560 BE.
Suggested actions
Reply 39 of 151, by KT7AGuy
I was curious about reports that Core 2 Duos are safe to use, so I threw Win10 on a PC with an E8600 just to see what came up. Here's what I got:
Windows OS support for kernel VA shadow is present: False
Windows OS support for kernel VA shadow is enabled: False
Suggested actions
* Follow the guidance for enabling Windows Client support for speculation control mitigations described in https://support.microsoft.com/help/4073119
Based on that, it looks like Core 2 CPUs are not safe to use unpatched.
