First post, by Ivanov
Hello guys, I need some help 😀
What hardware will be needed to cover all DOS games ever released and have them all working, looking and sounding at their best? I haven't really digged much into the DOS era and have barelly played any games of the period, and now I'd like to try all of them out and see which I like enough to keep and which are not worth keeping. I'd like to try them out on real hardware first, then compare that to emulators like dosbox and pcem to see just how accurate emulation is, and maybe sell the real hardware if Im satisfied with the emulation. I'm not sure what real hardware to get to test all that. I already know what sound cards games of the era used - pc speaker, tandy, covox speech thing, disney sound source, all the adlibs and sound blasters, MT-32 and SC-55, and the gravis ultrasounds. So what about CPUs? I'm guessing a 486DX2-66 and a Pentium MMX 233 should cover the late DOS games, what about older speed sensitive games? I think Wing Commander needs 386DX-33? And the early games need a 4.77mhz 8088, so I guess a Tandy 1000 for those? Anything else? Any games need a 286? And at what speed if so? How about something in-between the 386DX-33 and 486DX2-66? Like, is any 486SX or 486DX needed to cover any games? I'm fairly new to all this and all the internet research Ive done is confusing me... I'd like to try out all DOS games in order from oldest to newest using a wikipedia list of games ordered by year, and have appropriate hardware for all of them. Help pls 😀
Reply 1 of 25, by .legaCy
Super Socket 7 MB
Voodoo 3 3000 AGP
K6-3+ 550
Creative SB AWE64(if you are finicky about OPL sound fidelity, you can go with Yamaha audician 32, sb pro 2.0,etc)
this will cover about 95% of dos games, anything speed sensitive that would run on a 386(disabling caches and using setmul) up to late dos games will run fine.
Reply 2 of 25, by Ivanov
Thanks but how about hardware that won't need such tricks like disabling caches and using slowdown software, for at least my first go at these games, as if something isn't quite right and needs tweaking I'm afraid I might not notice it since I wouldn't know how it was supposed to be to begin with? Basically first impressions are important so I want for my first go at these games to use period correct hardware that will have them work as they should, guaranteed, and only after that for subsequent playtroughs I'll be fiddling with getting them running on newer hardware and emulators?
Reply 3 of 25, by cyclone3d
For a good all-in-one sound card to cover a bunch of things.. and to reduce costs greatly, get a first gen Aztech sound card.
Any of them with the AZTSSPT0592-U01 is a good choice as long as you are aware that they are speed sensitive - 133Mhz is supposedly around the threshold of what they can handle before they start acting funny.
You get Adlib, Covox/DSS, SB Pro 2.0 and Windows Sound System support from a single card.
See here:
Aztech Sound Galaxy cards
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 4 of 25, by dr_st
It makes more sense to start with the emulation, which is far simpler, and only head towards real hardware if you are not satisfied for some reason. It's just a million times simpler, cheaper and space-efficient.
Reply 5 of 25, by Ivanov
yeah, it's true that its simpler, cheaper and more space efficient, but if I haven't seen the game run on real hardware first, I wouldn't know if the emulation is 100% accurate to the real thing or not
Reply 6 of 25, by dionb
Well in that case there is clearly no single system that will cover all DOS games, as the last DOS games need something close to the specs listed by .legaCy. to run comfortably, but many of the oldest games would be completely unplayable (take a look at spacewar.exe on a system like that 😁 ), unless you slow it down *somehow*.
If you really want to cover everything with a system that can run at multiple speeds without unbalancing (no cache) or slowdown software, the best I could recommend is a very obscure early So7 motherboard I once had - Spring Circle P5C01 - that for some reason had an FSB you could clock down from 66MHz to 16MHz. Its performance scaled almost liniarly, so at 16MHz you had just over 1/4 of the performance you'd have at 66MHz. Downside was that it did not support split voltage, so unless you modded some kind of voltage regulator onto the socket (or found a Powerleap PL-K6-III 😉 ) the best CPU it could run would be the Intel PODPMT (Pentium MMX) Overdrive, or less unobtainium, a P54C-200. With a Pentium 200, you could do CPU speeds from 24MHz (1.5x 16) to 200MHz (3x 66), so a factor 8 difference in CPU speeds (and factor 4 in RAM and L2 performance, and assumedly a factor 2 in PCI performance) with a single system and CPU.
But eh... just try finding one of those boards 😉
Reply 7 of 25, by konc
OP mentioned "hardware" and "all DOS games". Never said one single computer 😉
So the answer is something like an XT and a 386 both supporting turbo on-off, plus some socket 7.
Reply 9 of 25, by dr_st
1. As a gamer, knowing if it's 100% accurate or not is not something that you should care about.
2. It's never 100% accurate, but DOSBox compatibility with games is almost perfect for every practical case.
If you want to dive into the world of assembling and tinkering with old junk machines, just for the heck of it, like many good folks here, that's one thing. 😀
If you just want to play DOS games and extract maximum enjoyment from them, it's simply unnecessary.
Reply 10 of 25, by jheronimus
It's really hard not to notice when a game is not working properly, trust me. Speed issues and crashes are really obvious. 😀
Yes. For example, 486DX@33 MHz is often considered an optimal CPU for Ultima VII.
Not really, but some people like 286 as their EGA/AdLib gaming rigs just because it's a bit faster and easier to work with than an XT. It can use regular IDE and 3.5" floppy drives, for one. And it's not restricted to 8-bit ISA hardware that is expensive and kind of tricky to find.
Honestly, I would start with a more common and fast system — like Socket 7 (Pentium, Pentium MMX, AMD K6) or Slot 1 (Pentium 2 and 3). These machines are usually cheap, common and run a great variety of games. Also, they allow you to experiment with a lot of hardware (sound cards, General MIDI modules, video cards) as you find different stuff. After a while you will understand whether you need older hardware and whether you like tinkering with retro hardware at all.
MR BIOS catalog
Unicore catalog
Reply 11 of 25, by jheronimus
Lucky Star 5V-1A reportedly can go all the way to 10MHz and does support split voltage. I have that board myself, but didn't have the time to try it yet. But yeah, having to mess around with jumpers every time you want to change speed isn't ideal.
MR BIOS catalog
Unicore catalog
Reply 12 of 25, by dionb
Nice link - that's some range!
And there is one on eBay at the moment for a not too extortionate price. Must... resist... temptation... 😜
Better than software IMHO, but not ideal. My idea for my next build (first So7 system I'm touching in a decade) is to replace the jumper caps with leads to toggle switches, so you can just flip the switches instead. Not sure that's something you should do on-the-fly, but even if you do the sensible thing and power down first, it avoids grubbing on the board every time.
Reply 13 of 25, by God Of Gaming
if I'm not mistaken switching the multiplier on the fly should work fine but switching the FSB will freeze the system so you do need to power it down for that. Still, that seems like a great idea, you can get some switches on a 5.25" panel that should do the job. This is indeed an interesting motherboard, I wonder if it will be capable to cover all DOS games by itself
1999 Dream PC project | DirectX 8 PC project | 2003 Dream PC project
Reply 14 of 25, by cyclone3d
Way back in the day when I was running a 486 DX2-66 as my only computer, I had installed a jumper on the front of the case with the wires going to the motherboard in order to be able to change the FSB between 33 and 40Mhz without having to open up the computer. I used to switch the speed with the system powered on and it never gave me any problems.
That was only a single jumper though so unless you can switch a single one at a time in order to eventually jump down to what you want it isn't really going to work when you have to change multiple jumpers.
YMF7x4 Guide
Reply 15 of 25, by CelGen
Hey Ivanov.
If you want to cover DOS I personally have no problems with machines setup like so:
-Socket 3 motherboard with a 66mhz 486 (DX or DX2. Doesn't matter too much)
--You can use a Socket 5 or 7 machine with a Pentium chip if you don't want to pay the premium 486 systems are going for right now
-16mb ram (you can get away with 8 in many cases but these days 30 and 72 pin ram is pretty cheap)
-Sound Blaster 16
-Basically any VESA mode compatible video card, we'll use for example the ATI VGA Wonder as they are quite plentiful.
--Keep in mind though that many of the classic DOS games are CGA and EGA. A VGA card will still play them but CGA/EGA emulation on VGA is not perfect, but your option is to shell out for a proper CGA or EGA card and a compatible monitor. I'm assuming you don't want to spend a lot of money.
Optimally I'd be running a 40mhz 386 (I can also suggest just a regular 33mhz chip as they are cheaper but you will start seeing issues on some of the late DOS games) machine that has a toggle for Turbo, but otherwise the sound and video cards would remain the same.
I'm not sure exactly why half the people on this forum insist you have hot-rodded system specs better suited for Windows 95/98 gaming. DOS gaming isn't rocket science unless you demand it be *perfect*.
Reply 16 of 25, by lvader
On a Cyrix 5x86 you can change FSB on the fly, and adjust between 3x and 1x (or 2x and 1x with software.
On a socket 7 Pentium setup you can switch FSB and multiplier on the fly but they only take effect after a reset.
Reply 17 of 25, by konc
Yeah it's nice and everything slowing down a faster machine, but what about CGA games? That's why I also mentioned an XT. Of course most people don't care about them, but the title says "all" 😉
Reply 18 of 25, by BeginnerGuy
Cautionary update: I now realize I'm confusing my IBM models, I had it in my head that AT represented the original 4.77MHz 8088 and that a 286 would turbo down to compatibility for it:
XT 286 8MHz is a total must if you want to cover "all" dos games in my humble opinion. You can drop it down to AT speed for your 1981 needs and it will also handle graphic adventures and even the first Keen games happily (if you're lucky enough to have enough RAM) in EGA glory.
I see this conversation constantly and everybody has their own list.. Here's mine..
286 8mhz (1981-1990 - minus 'high end' late 80s games).
486 ~33-66mhz (disable l2 cache and smack the turbo button for an instant 386, possibly disable l1 cache if it's a faster 486). This will cover late 80s all the way up to the end of dos (as long as you don't mind duke3d in 320x200).
Socket 7 P5 || MMX ~200 to run anything later to run in high res like butter (1993 - infinity) dos. Or just build a Slot 1 win98 machine to cover this era and 9x all the way up to ~2001.
Sup. I like computers. Are you a computer?
Reply 19 of 25, by konc
BeginnerGuy wrote:
XT 286 8MHz is a total must...
I need to get one of those 🤣 OK just joking, I see you wrote the other way around the "AT that you can drop it down to XT speed".
Although that's not entirely true for the very few 4.77MHz things, so if you really need to cover "all", you need a 4.77MHz capable XT and a CGA for the correct colors.
The dedicated CGA PC is far more important in my opinion than the XT. How else can you get the correct CGA colors? That's why for me a single PC is not enough, no matter what speed you can bring it down to. Of course this does not apply for most people who maybe haven't ever seen a true CGA and don't have any interest in such old games.
