Reply 380 of 539, by ConventionalMemories
ediflorianUS wrote on 2020-12-22, 21:48:So it needs a bios update ... hmm... probably you also need to pull the chip to do that ... I am great but I am not that great o […]
my03 wrote on 2020-12-22, 16:52:I guess it complains simply because it will not recognize anything other than the (three?) Conner models that it would actually support when you use the original bios (i assume you don't use a modded bios?).
I use AnyDrive on a different 286 (Its a Victor/Sirius 286P) successfully but i don't think that model is as locked down as the Toshibas. But i "think" i saw someone (in the middle of this thread) that had some modded bios also for your model (look for it) and with luck, that version removes the whitelist...
So it needs a bios update ... hmm... probably you also need to pull the chip to do that ... I am great but I am not that great of a user...
I felt that some steps I skipped by mistake , and hoped that I can remediate(redo) those steps....If i wont succeed(classic way) I will probably abandon my upgrade and restore factory drive....
Reading other posts about EZ-Drive , I gathered there should be a setting Type 9 in bios ? ”If you system bios dose not have auto config or userdefind, select Type 9” ...
Hmm seems like there isn't any BIOS patch available already for the t3100e.
so this seems like a good time to introduce my project to this forum.
https://www.benl.ebay.be/itm/264877993192
This is an expansion card that goes into the special toshiba expansion slot.
It provides an XT-IDE BIOS in ROM as well as an CF card slot that's easily accessible from the back of the machine.
It is compatible with many Toshiba portables from the T1100+ all the way up to the T5200
One of the more interesting features that i think many people here will find useful, is that it can also easily be configured to control the internal IDE controller on machines that have one. (T3100e, T3200sx(c), T5100, T5200(c))
This allows you to have both an easily accessible CF card slot as well as the ability to change out the internal drive without running into the restrictions of the Toshiba BIOS.
I hope some of you will find this helpful
