Right, I suppose we are talking about the same thing, just in our own words and expierence: Jumperfree and Jumpered.
There are 4 multiplier request signals BF0 tot BF3, which are actually physical fingers or pins on the CPU slot cartridge. But they are only probed as such by the CPU at reset. This makes for a max. of 16 possible multiplier request signals. The actual meaning of these signals differ from CPU to CPU. Like the Tualatin core has entirely different mapping compared to a Deschutes. I do not expect any jumperless motherboard out there to support all the possible exotic multipliers on both Klamath/Deschutes AND Engineering samples of the PIII. Also I would not expect a jumperless board to have two variants of 2.0x selectable.
But in case a jumperless board has the settings you need, and the board is working well in all respects, it should not matter that much. Also it would not hurt to know beforehand exactly how this matter works.
