First post, by Vipersan
So I dug this programmer out ..and tried it ..
I powers up ok but I have no software so basically it is just a doorstop atm ..
Perhaps someone recognises it ..or perhaps had/has a similar unit ..
It is a throw back to early PC ..DOS even ?
It is connected via LPT to the PC ...and uses its own psu.
The Name on it is Micromaster 1000 ...made by what was a UK company ICE Technology ..
Can anyone help me here ?
It would be such a useful item to have working again ..
rgds
VS
    301.44 KiB
    294.18 KiB
Reply 1 of 3, by cyclone3d
Here is the wayback machine for the old download page.
However, the ftp it goes to is not archived.
The ftp site is still active though so maybe, just maybe they still have the old software on there. It looks like there isn't public access anymore though so I couldn't look.
https://web.archive.org/web/20100424212714/ht … 01/download.htm
Also, here is a spec sheet.
http://www.farnell.com/datasheets/11810.pdf
Oh.. and look here. I think I actually found the software.
It was posted here:
http://www.edaboard.com/thread360053.html
winlv_10241b.zip
2.78 MiB
41 downloads
Here is a link that has a newer CD version of the software, but it looks like it is only for the newer programmers.... but maybe not.
https://www.retrocomputers.online/ice-technol … tware-2-0-0009/
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 3, by Vipersan
Thanks Cyclone ..
It does indeed look like this programmer was intended for DOS use ..
but ..at least I have somthing to try..
looks like the 1000+ version runs under windows..the plus being the key.
If anyone knows otherwise ..please comment here..
rgds
VS
Reply 3 of 3, by cyclone3d
Vipersan wrote:
Thanks Cyclone .. It does indeed look like this programmer was intended for DOS use .. but ..at least I have somthing to try.. l […]
Thanks Cyclone ..
rgds
VS
Look at this page.. it is linked from the other one I posted above.
https://web.archive.org/web/20070202213529/ht … her/softold.htm
The version I attached should definitely work for the 1000.
YMF7x4 Guide
