486sx and 486dx
Re: 486sx and 486dx
Postby derSammler » 2018-2-02 @ 10:19
Yes, that would make sense. But then the jumper selects which CPU to use, and not really if an FPU is present. :)
derSammler
Re: 486sx and 486dx
Postby Scali » 2018-2-02 @ 10:21
derSammler wrote:Yes, that would make sense. But then the jumper selects which CPU to use, and not really if an FPU is present. :)
Well, I think that's a given... The FPU is internal, so only the 486 chip used determines whether the FPU is present or not :)
I don't think it's possible to disable the FPU in a 486DX externally.
Scali
Re: 486sx and 486dx
Postby CkRtech » 2018-2-02 @ 10:26
Different jumper configurations for SX vs DX on a 486 is pretty normal stuff. I just assumed it was chipset related.
User avatar
CkRtech
Re: 486sx and 486dx
Postby RobertJ » 2018-2-02 @ 12:55
Scali wrote:
badmojo wrote:Never heard if any game taking advantage of it, could you provide an example?
Falcon 3.0 had an enhanced mode if you had an FPU.
That's the one I was specifically thinking about. It was one of my favorite flight sims of that era, and the reason I upgraded to a DX at the time.
8-bit Collection: 4 64Cs, 6 1541-IIs, 1 C128, 2 1571s, 1 C128DCR
Vintage DOS: Dell Optiplex G1, AMD Rage IIC, Sound Blaster CT4520, Thrustmaster FCS Mark II, Gravis PC GamePad
Monitor: Dell 20" 2007FPb
User avatar
RobertJ
Re: 486sx and 486dx
Postby Baoran » 2018-2-02 @ 13:41
This is almost same as the motherboard I have: http://stason.org/TULARC/pc/motherboard ... 0037S.html
One of the differences is that one of the jumpers that is suppose to tell the cpu type to the motherboard is missing.
As you can see where the JP27 is suppose to be, there is no jumper.
Another difference is that there is winbond chip where it says "real time clock" in the picture and there is a barrel battery next to the keyboard connector.
Baoran
Re: 486sx and 486dx
Postby vladstamate » 2018-2-02 @ 14:00
Another software I used a lot that required FPU was VistaPro. I still have that installed on all my retro PCs starting from 386 to Pentium III. Very fun software to play with.
User avatar
vladstamate
Re: 486sx and 486dx
Postby Baoran » 2018-2-04 @ 09:20
Quake benchmark works 3.8 fps no matter how I set the jumpers, so no idea what the jumpers actually do.
Baoran
Re: 486sx and 486dx
Postby Scali » 2018-2-04 @ 12:09
Baoran wrote:Quake benchmark works 3.8 fps no matter how I set the jumpers, so no idea what the jumpers actually do.
Perhaps it's just to set the correct CPU model at the BIOS POST screen?
Does it change from SX to DX?
Perhaps you could also try running some CPU info software from Norton or such, which try to determine the CPU type independently, and see if they change based on the jumpers?
Scali
Previous
Who is online
Users browsing this forum: knowledge [bot], Zup and 7 guests
