FLASH EEPROM identification help!
Discussion about old PC hardware.
Postby Doppler » 2018-2-02 @ 11:03
Hi!
Can anyone identify this chip? I try to programm it with external USB flasher but can't find any refrence for it in the flash software. Non of these numbers fit to the predefined chip profiles.
The chip is DIP28 pulled straight out of the S3 Virge/GX2 AGP SG200A graphics card.
Heres the photo:
Doppler
Re: FLASH EEPROM identification help!
Postby Predator99 » 2018-2-02 @ 11:33
I would say this is a ROM, Read-only. You can read it as standard i.e. 27C256, but not rewrite it.
Predator99
Postby derSammler » 2018-2-02 @ 11:38
If "SG200A" is also the name of the card, then yes, this is a masked ROM.
derSammler
Postby Auzner » 2018-2-02 @ 11:43
Do people swap these out for EEPROMs to run a different BIOS? What's the advantage for the card?
User avatar
Auzner
Postby derSammler » 2018-2-02 @ 11:49
Brightness fix, I guess. ;)
derSammler
Postby Doppler » 2018-2-03 @ 22:13
derSammler wrote:Brightness fix, I guess. ;)
yup!
Doppler
Postby Doppler » 2018-2-06 @ 07:06
Is it possible to directly replace this ROM with flashable memory? In other words: if I buy and flash a Winbond memory with the S3 BIOS and swap these chips, then will it work?
Doppler
Postby Auzner » 2018-2-06 @ 07:23
yes
User avatar
Auzner
Postby lazibayer » 2018-2-06 @ 07:24
Doppler wrote:Is it possible to directly replace this ROM with flashable memory? In other words: if I buy and flash a Winbond memory with the S3 BIOS and swap these chips, then will it work?
Highly likely it would work.
User avatar
lazibayer
Return to General Old Hardware
Who is online
Users browsing this forum: Duouk2000, Google [Bot], Nprod, Nvm1, PARKE, uscleo and 17 guests
