Need Help With Amptron Socket7 PM-9100LMR Power and Front Panel Connections
Postby tegrady » 2018-2-03 @ 14:20
Hi, I have an Amptron Socket7 PM-9100LMR motherboard. However, I do not have the manual and I cannot seem to find one online.
I am trying to hook up the power button, reset switch, hard drive led, etc. However, the motherboard does not mark these connections like a modern motherboard.
I assume that the connectors are the group in the bottom right corner of the board, but I am not sure.
Does anyone have this manual or can you tell me what goes where? Thanks.
User avatar
tegrady
Re: Need Help With Amptron Socket7 PM-9100LMR Power and Front Panel Connections
Postby konc » 2018-2-03 @ 15:20
Amptron are rebranded PcChips motherboards. The layout of your motherboard looks identical -at least for the part you're showing us- to PcChips M571LMR.
It also has a 22-pin jumper array labeled J8, with pin 9 missing.
Manual extract for (J8):
Needless to say that you're doing it on your own and please don't blame me in case of fireworks. I would definitely try this legend and I'm personally convinced it's correct, but I had to say this ;)
User avatar
konc
Postby dionb » 2018-2-03 @ 15:29
Note that you only need / can use the power switch on the front panel if you are using an ATX power supply - i.e. a PSU with soft power on. AT power supplies (that connect to the M8/M9 connector next to the ATX 20p connector) don't have soft power on, just a hard physical switch on the external (mains voltage) side wired to the PSU, not to the motherboard.
User avatar
dionb
Postby tegrady » 2018-2-03 @ 16:31
Thanks! You are awesome!
And yes, I am using an ATX power supply.
User avatar
tegrady
Who is online
Users browsing this forum: cliffclaven, dirkmirk, Google [Bot], jesolo, overseer, realoldguy23 and 8 guests
