How do I set up this AT case speed display?
Postby appiah4 » 2018-2-09 @ 10:45
I have an AT case that comes with a three digit 7 part LED display for speed. I want to set it to the current Processor speed of 133, but when I removed the front panel and checked the control card, I found this:
The two top pins were actually connected to 12V from a molex source, I removed it in order to remove the front panel. There are absolutely no jumpers to set what it displays, and currently it displays "0", as in nothing in the first two digits, last digit shows 0.
Anybody have any idea on how to set this thing up?
A500:Rev6|512K+RTC|ACA500+|HxC/df1|C1084S
1994:PCI597-1|P133|32MB|Trio64|ES1868/S2
1997:S1573S|K6-2/400|64MB|M220|V2-SLI|CT4500/32M
2000:GA-BX2000|P3-700E|256MB|GF2GTS|MX300
DELL:GX110LP|PIII-1000|512MB|G450|128i/X3M
User avatar
appiah4
Re: How do I set up this AT case speed display?
Postby derSammler » 2018-2-09 @ 11:16
Probably by setting jumpers on the 2x6 pins?
derSammler
Postby appiah4 » 2018-2-09 @ 11:26
derSammler wrote:Probably by setting jumpers on the 2x6 pins?
They are not jumper pins as far as I can tell but rather solder points for the led sceen behind the card.
Also, this design seems to have popped on Vogons before as well: viewtopic.php?f=46&t=46110
The only other resource I could find was another forum post discussing the use of the same panel on an arduino: http://forum.arduino.cc/index.php?topic=12156.0 which seems to confirm that it's not programmed with jumpers in a traditional way, but rather displays numbers stored on the IC depending on whether Turbo header is short or open..
I vaguely remember some leds being programmed by pressing down some case button or another? Ie enable turbo, hold some button and get the number you eant; disable turbo repeat? Anyone know such a method?
User avatar
appiah4
Postby appiah4 » 2018-2-09 @ 11:50
Deep diving on archive.org revealed the answer:
https://web.archive.org/web/20080220034 ... /0669.html
Hi
In the + - pins you have to conect the power(+5V and GND)
The yellow led is computerīs turbo led
The display shows you the frecuency of your computer. If you press the reset button for 4 or 5 seconds, the number on the display increase, thats the way to "program" it.
It can memorize 2 numbers, one with turbo switch pressed (yellow led on), and another one with turbo switch unpressed (yellow led off).
Leaving this here in case anyone needs it later on.
User avatar
appiah4
Who is online
Users browsing this forum: dimvez, Skyscraper, Yahoo [Bot], Yesterplay80 and 12 guests
