IBM Model M 1987: Remapping the right Alt key as the WinKey?
Discussion about old PC hardware.
Postby bjwil1991 » 2018-2-09 @ 19:38
I have 2 retro computers running Windows 95C on them, and they both share the same keyboard, mouse, and monitor thanks to the magical NIB KVM 4-PC PS/2 VGA switch box. However, I forgot the older Model M keyboards up until the late 90's or so (excluding the ThinkPad systems) don't have the WinKey. On my ThinkPad R40 in Windows XP Pro SP3, I remapped the right Alt key to be used as the WinKey (Super for Linux, or Command/Apple for Mac OS). Is there a particular program to remap the right Alt key to be used as the WinKey? I know I can use the Ctrl-Esc combination, but if I need to go to the system properties in Windows 95 if I'm doing routine maintenance on my computer mouse, pressing Ctrl-Esc-Pause/Break won't cut it, unless I use the arrow keys to go to Settings > Control Panel, hit the tab key, and use the arrow keys again to get to the System Properties panel.
C64, WheelWriter 10 Series II QuietWriter 8, Pack-Mate 28 Plus, K6-2/300, Pavilion N3350, iMac G3 & G4, Socket 370, 2x Inspiron 600m, Athlon 64, Dimension 4550 & E510, ThinkPad R40, Presario C700, ASUS X54C, Raspberry Pi B+, 2B-3B+, Custom FX-6300
User avatar
bjwil1991
Re: IBM Model M 1987: Remapping the right Alt key as the WinKey?
Postby Nprod » 2018-2-09 @ 19:52
Perhaps an old version of Autohotkey might do the trick?
User avatar
Nprod
Postby konc » 2018-2-09 @ 22:41
I don't have an answer for your question, but you know you can create a normal windows shortcut for the Control panel's System icon and place wherever is convenient for you, right?
btw, what's your routine mouse maintenance schedule? Seems a little too frequent :lol:
User avatar
konc
Postby bjwil1991 » 2018-2-10 @ 02:50
Cleaning the X and Y axis since there's always dust that gets collected and gets stuck on there, causing the mouse to act funny.
User avatar
bjwil1991
Return to General Old Hardware
Who is online
Users browsing this forum: Thermalwrong and 8 guests
