First post, by keenerb
I've found three COAST modules in a big bag of 72pin DIMMS I got recently.
They look functionally similar, and I have a few motherboards with COAST slots, but I can't recall whether there were significant differences in voltage/etc. I need to worry about...
Reply 1 of 10, by moturimi1
You can use any COAST module.
Reply 2 of 10, by fitzpatr
The only exception of which I am aware would be the PCChips M919, which has a very different type of COAST Module, which is actually Static RAM Cache on a stick, rather than Asynchronous Cache (Pipeline Burst). It is not electrically compatible with a normal COAST module.
    637.66 KiB
    PCChips M919 Cache Module
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 3 of 10, by derSammler
Actually, COAST modules are not always interchangeable. Not all are Pipeline Burst Cache and don't expect COAST modules from a Mac to work in a PC. You won't cause any damage trying, however. It either works or not.
btw, that M919 module is a COAST module as well. And according to the M919 manual, later versions of the board (or BIOS, dunno) support Pipeline Burst Cache COAST modules as well.
Reply 4 of 10, by fitzpatr
I do have the M919 manual, board, and pictured COAST module, but although they mention support for a Pipeline Burst module, I'm not aware of any ever being released. In this below linked thread, feipoa has been unable to get and any Pipeline Burst modules functional in an M919. The module also has a warning that it is only for M919.
M919 owners
I would certainly believe that not all modules, M919 aside, are interchangeable.
FIC PT-2003 COAST module supportThis thread provides more information as to the types of issues that can arise.
486 Build
Reply 5 of 10, by derSammler
The manual I have shows an older revision of the board and states that PBC modules are supported in the future. I own the last revision of the board but have not tried a PBC module yet. It's also possible that it would have required a BIOS update. Anyway, the point is that the M919 has a normal COAST slot just like any others. And that backs up the statement that COAST modules are not always interchangeable. 😉
Reply 6 of 10, by fitzpatr
That's the and thing mine says. I guess we'll need to head to the other thread and do some testing!
So to sum up, OP, it depends on how new the board is. It seems that newer boards accept more modules.
486 Build
Reply 7 of 10, by lazibayer
I had pretty bad experience with COASTs on a 486 board - FIC 486-GAC-2. I tried two COASTs - one from compaq deskpro, and one from Olivetti - neither worked. Computer won't boot when COASTs were installed.
For pentium boards, one tricky part is to get the tag-ram configured to the right specification.
Reply 8 of 10, by Tetrium
Are the Compaq Coast modules even compatible with standard PC stuff?
Compaq (and other companies like for instance Dell) liked to do things...differently, so to say 🤣
My retro rigs (old topic)
Report spammers here!
Reply 9 of 10, by lazibayer
I don't know if there was a "standard" for COAST in 486 era...
Reply 10 of 10, by elianda
Also for Pentium systems different COAST modules were used. Most notable there are mainboards that use COAST modules with Tag and some without Tag RAM.
e.g. look at this docu for the Shuttle HOT-4515 Layout V2.5 in the section 'Versionen':
http://www.shuttle.eu/_archive/older/de/541.htm
It states 'hierzu ist ein besonderes 256 kB Modul (ohne Tag-RAM) notwendig', which translates to 'here a special 256 kB module (without Tag-RAM) is required'.
Youtube Channel
