First post, by keenerb
I picked up a Tandy 1000HX and CM-5 monitor last weekend. The motherboard powered on a few times, but then stopped working, power supply seems completely dead.
I disassembled the unit and see nothing wrong; the power supply fan spins if I disconnect the main power lead to the motherboard, which is not a very reassuring sign.
Teardown photos: https://imgur.com/a/lJ8Rd
Anything look like a problem there?
