First post, by britain4
Got another issue with my Libretto 110CT which is that vertical “lines” have started to appear on the screen. It looks like half of every pixel is slightly darker than it should be making everything look vertically “striped” rather than a uniform colour as it did before. More pronounced on grey and invisible on white.
I’ve tried reseating and cleaning the display connector, removing the optional RAM module and connecting to an external screen to verify it doesn’t do it there (it doesn’t). There was a very slight trace of corrosion on the screen connector on the board but it’s all cleaned off.
It comes and goes “suddenly” and disappeared once while the laptop was turned on. It is an issue in both Windows and the BIOS so I think it’s probably a hardware fault with either the display or connector.
Any suggestions as to what I should try next? I haven’t tried disassembling the screen to check the connectors behind there but I’m not sure that would help.
- P-MMX 200MHZ, PCChips M598LMR, Voodoo
- P-MMX 233MHz, FIC PA2013, S3 ViRGE + Voodoo
- PII 400MHz, MSI MS6119, ATI Rage Pro Turbo + Voodoo2 SLI
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500
- Toshiba Libretto 110CT, 300MHz, 96MB RAM
Reply 1 of 1, by timb.us
I’d check the connector behind the LCD to be safe. Just make sure you’re *very* *very* *very* gentle when removing the bezel around the LCD. That plastic doesn’t age well and will completely snap on you if you even look at it funny. Use a credit card to pop it up (insert it from the inner screen portion).
You might also try a tiny drop of DeoxIT Gold on the motherboard side of the video cable (applied with a lint free applicator). I like to start with a bit of regular DeoxIT, rub it in, let it sit, wipe it out with a clean applicator and then apply the DeoxIT Gold. Works wonders on contacts exposed to corrosion.
Any sufficiently advanced technology is indistinguishable from magic. (E.g., Cheez Whiz, RF, Hot Dogs)
