Commodore PC-10 and HD floppy drives
Discussion about old PC hardware.
Postby Kubik » 2018-3-08 @ 13:42
Folks, does the floppy controller in PC-10 support HD floppy drives? I am wondering if it makes any sense to try one of the HD floppy option ROMs, but if the HW shouldn't support it, it would be a waste of time.
Thanks!
Kubik
Re: Commodore PC-10 and HD floppy drives
Postby derSammler » 2018-3-08 @ 14:00
No, it can handle DD drives only.
derSammler
Postby Jo22 » 2018-3-08 @ 14:30
The problem is that old FDCs (floppy disk controllers) have to little bandwith. They run at 256KBit/s only.
HD floppy drives do require 500KBit/s, however, to run in native mode.
Otherweise, they still work, but act like they were DD drives
(though not fully compatible with DD media).
As a workaround, you could try to disable the internal FDC and use a third-party FDC controller card w/ HD support.
It has been discussed at forum.classic-computing.org
English translation
Edit: Also note that Commodore used the Shugart wiring; not the IBM-style wiring.
User avatar
Jo22
Postby Kubik » 2018-3-09 @ 07:37
Thanks, guys, it looks like I have to stay with DD and eventually add 3.5" DD drive, because I am not sure I'll have enough ISA slots for another controller.
Kubik
Return to General Old Hardware
Who is online
Users browsing this forum: God Of Gaming, Shagittarius and 13 guests
