PS combined watts required for 3.3v/5v rails?
Discussion about old PC hardware.
Postby buckeye » 2018-3-08 @ 19:33
Pertaining to a Asus PB3-F/P3 850mhz-100/256mb/GF3/V2sli/Aureal Vortex2/30gb drive set-up? Have a 350W Thermaltake but the 3.3v/12v rails combine for only 120 watts, which I'm thinking won't be enough. Should I look for something along the lines of 180 watts?
Intel SE440BX P3 450 384MB 40GB Hercules 3D Prophet II Ultra 64MB SB Live! 5.1 350W 98SE
Foxconn Q45M E8400 Core2 Duo 2GB DDR2 800 160GB BFG Geforce 7950GT 512MB 500W XP SP2
Asus P3B-F P3 850 512MB 40GB Abit GF3 64MB Voodoo2 SLI Aureal Vortex 2 400W 98SE
User avatar
buckeye
Re: PS combined watts required for 3.3v/5v rails?
Postby Skyscraper » 2018-3-08 @ 19:43
Motherboard, memory and CPU ~30W
Geforce III Vanilla ~40W
2x Voodoo II lets say ~20W
HDD and the rest less than 30W on those rails for sure
I think it would work but I would get a better suited PSU anyhow.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 780 Ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Skyscraper
Postby dionb » 2018-3-08 @ 19:45
The CPU gets its power from the 5V line, as with other pre-P4 designs. 12V is only used for keeping drives spinning, so you really don't need much there. It should be fine. Let's turn the question around: *why* do you think 120W on 3.3V and 12V combined won't be enough?
User avatar
dionb
Postby Skyscraper » 2018-3-08 @ 19:47
dionb wrote:The CPU gets its power from the 5V line, as with other pre-P4 designs. 12V is only used for keeping drives spinning, so you really don't need much there. It should be fine. Let's turn the question around: *why* do you think 120W on 3.3V and 12V combined won't be enough?
I think he wanted to say +5v and +3.3V combined. :)
Skyscraper
Postby dionb » 2018-3-08 @ 20:39
Yes, it's a bit ambiguous between title and topicstart. If it's a low-end P4 style 350W PSU instead of a mid/high end Athlon style I see the challenge - but even so this should be fine, although you really want a PSU that delivers most of its current on 5V for a system like this. Good thing good early ATX power supplies aren't considered highly valuable collectibles yet (except perhaps amongst Antec fanboys ;) )
User avatar
dionb
Postby buckeye » 2018-3-08 @ 22:55
The last board I had, the SE440BX-2 wouldn't boot with it, it only liked an 350w Antec only. I remember reading somewhere else that 180w was the threshold to look for, I'll try it out and post the results.
User avatar
buckeye
Postby buckeye » 2018-3-08 @ 22:57
Oops, yer right, I stand corrected!
User avatar
buckeye
Return to General Old Hardware
Who is online
Users browsing this forum: TheAbandonwareGuy and 6 guests
