First post, by Jed118
This build extends my first build (Intel 1979-1995) with new chips (1996-2011)
This is an ongoing build, which is as of this post about 80% complete. What started off as an empty Polish honey box (containing three natural honey containers) which has been taken apart and reduced in height by about an inch (I have before pictures somewhere, will load later), glued, stained, drilled, recessed, and armed with analog electronics. I used a 486 with Photoshop 4 to create the CPU backing with the information about the processors.
Here's the build process, it started some time in Nov 2017 and has had a few delays attributed mainly to waiting for parts from China.
Here's the process
Cut down an inch and sanded
Measuring divider height (also had to be cut down)
Stained
First LED test:
https://youtu.be/JP8xyjijT-Y
I was going to use just white LEDs but my co worker had used strips of these, and I wouldn't have to recess them so I gladly accepted this gift. It's all analog, and part of the issue is that the POTS are driving LED intensity as well as colour, but for what it's doing I'm fine with it.
Drilling super-precise, totally in line holes for the POTS using only the finest drill press (hah)
Because I had bought the knobs first before the POTS came in, they did not entirely fit. A dremel to the POTS sorted that, and I put the knobs down on a belt sander to take off excess so that they would recess into the precise holes I made:
After ensuring knob alignment, I stained the holes:
Time to add the guts - simple RGB LED strips connected to three POTS for R, G and B. There's an on/off switch that supplies positive to the LED rails (RGB is handled by ground) - a 9V and two AAA's wired in series give the unit 12v.
The thing kind of looks like some 70s electrical appliance, and I will be adding a small VU meter connected to the POTS to act as an ammeter on the left corner there just to complete that illusion (ordered VU meter today) - I was thinking of putting an antenna on the other side for fun too.
There's the backing - this plate comes out completely to be able to change the batteries. The CPUs will be attached to this.
Here's a short vid of it in action.
https://youtu.be/KfJxuFfFFDY
What remains to be done - The CPU information to be printed to a smaller scale and laminated, glued to the backing, and then the CPUs glued to that. The plexiglass is to be replaced with actual glass and the Intel Inside sticker added to it. As well, I will have to figure out some frosted vinyl stickers and cut them out using an interesting font to display 1996-2011. I'll also experiment with some diffusers, but they have to be thin enough to not impede the movement of the CPU backing. That and the aforementioned VU meter 😉
What's for sale? my eBay!
Reply 2 of 5, by Tetrium
It looks nimble, but nice 😀
It does look a bit small?
Just make sure the batteries don't start to leak 😜
My retro rigs (old topic)
Report spammers here!
Reply 5 of 5, by Jed118
Almost done, just waiting on a source for the date lettering on the glass.
It has a real piece of custom cut glass in there, no more lexan.
I also added a retro LED and VU meter to make this thing look more like a 70s piece of homebrew equipment.
The gauge actually moves when you adjust the green color varistor.
All that remains is to find lettering to affix to the glass under the Intel Inside logo (1996-2011) and to put tiny hinges on the back battery compartment.
^^^ Interesting image name that imgur generated there...
I've added some diffusers to the LEDs, and this caused the CPU tray to get stuck and require breaking the glue each time the batteries went flat. The first time that happened, I broke several of the tiny RGB leds so I had to re-solder a new strip on one side. Now I am loading the batteries from the rear.
I also had to carefully measure and add a strip of electrical tape to the glass to hide the gap between the diffuser and the LED strip. It can be seen when the glass is out. Otherwise, I'd say it's 95% complete.
