First post, by buckeye
- Oldbie
Have an Asus P3b-f 1.04 based build and during boot up get a hardware monitor error which the the bios shows the case fans speeds in red. I'm guessing that the mobo thinks the fan speed is too slow, don't know how to speed them up so I change the setting to "ignore" and all seems to be fine. Cpu and mobo temps are at 104 and 98 degrees F at idle. Cpu fan did not register an error which got me thinking the (2) case fans are bigger at 120mm ea. so would run slower. Guess what I'm asking is how do I speed them up or do I even need to? The case in question is a Rosewill Blackbone - cheap but seemed like an ok choice for a retro build.
Intel SE440BX P3 450 256MB 80GB SSD Radeon 7200 64mb SB 32pnp 350W 98SE
