First post, by okenido
ATM I'm testing a lot of builds to see how they perform. Recently I was very impressed by the performance of my Intel WS440BX motherboard (from an old Gateway computer), Windows98 literally boots in 5 seconds with an SSD, and is very snappy with a PIII 650mhz and 128mb of RAM.
Yesterday I tried the same Windows98 install on a Via Apollo Pro 133A-based motherboard (Asus P3V-4X), with a beefier CPU (pIII 933mhz) and more RAM (256mb). Surprisingly, it seemed slower. I didnt tried any game or benchmark, but in overall it took more time to install, was slower to boot and seemed a bit more clunky when it comes to peripherals like USB key detection.
I admit I didn't messed up much with with BIOS settings, most things are set to defaults on both motherboards. 440BX didnt required any drivers while VIA required its "4-in-1" driver.
Is it possible that the 440BX chipset, despite its 100mhz fsb, is more optimized to the point of being faster than the Via chipset which uses 133mhz fsb ? Would you suggest me a benchmark to put values on those feelings and check if something is wrong ?
