First post, by Aglenoth
Hello gentlemen, i have reinstalled this laptop with Windows 98 and Iam now unable to get into BIOS , what should i do were there some proprietary windows 95 compaq discs containing BIOS ?
Thank you for any advice 😀
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 1 of 2, by Falcosoft
https://www.experts-exchange.com/questions/10 … mada-1575D.html
You have to press F10 at the moment that, during boot, the white block appears in the upper right hand corner.
This only works if there is a diagnostics partition on the harddisk. Mostly this is the case. You can see it if you run fdisk.
If this diag partition is not there, you will have to boot from the floppys meant for this event. These floppy's can be downloaded at http://www.compaq.com.
Your BIOS is ok, but without the system partition or floppies to access the BIOS, you won't be able to make changes to the BIOS. Remember, if there is no system partition (shows as a Non-DOS partition in FDISK), the white block will not appear in the right corner. If it is not there, you need floppies as per joopv's recommendation.
So the problem can be that you have re-partitioned/formatted your HDD before installing Windows so now your diagnostics partition is gone.
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 2 of 2, by Aglenoth
Thank you very much 😀
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
