First post, by kingcake
- Oldbie
Are they gold or tin plated?
I recently took in a poor old Socket 7 motherboard (Which posted fine and booted into dos) but the cpu was stuck in the socket. After prying it out I noticed I can hear a crusty crunching noise when I operate the zif lever.
I noticed the rest of the board has some rust and corrosion like maybe it was used on a boat or something.
Is it worth blasting out the socket with IPA/Deoxit or should I just buy a new AMP socket on ebay and try my hand at replacing it (Never done this before so a little hesitant.)
Thanks.
