First post, by vt4000
Hi all,
I recently picked up a Gigabyte GA-BX2000 Slot-1 motherboard at a local PC recycler and have been trying to get it up and running. I'm using a Pentium III 500 MHz and an NVIDIA RIVA TNT2 M64 video card.
When I first boot the system up, I get the police siren beep code (high-low-high-low repeating) and get stuck on this glitched BIOS screen:
If I remove the CMOS battery and turn off the power supply for about 5 minutes, I get a successful POST, but a "Backup BIOS Checksum Error". I then see this screen, which I think is the system trying to flash the Backup with the Main BIOS:
Things I've tried so far:
I was able to get it to boot from a floppy (after removing all power and the CMOS battery for 5 min) and used the DOS utility to flash the BIOS. The date at the bottom of the screen has changed from 1999 to 2002, but I still get the glitched screen and a freeze on reset.
I tried about 5 different CPUs (Celeron, Pentium II and III). I noticed if I used a slower CPU (Celeron 300 instead of PIII 500), it would actually do the memory test while on the white screen, but freeze afterwards.
Tested 3 different PSUs with the same results.
Tested varying amounts of RAM and slots with the same results.
Tried clearing the CMOS using the jumper - no effect
Does anyone have any ideas of how to reflash the backup BIOS and exit this annoying loop? Unfortunately the BIOS chips are soldered down.
