First post, by henrikwils
I'm having a lot of problems with my ASUS VL/I-486SV2G. I've seen a few variations of this motherboard. Mine is a rev 1.8 non-X4 without power regulator and VLB slots.
First of all, it HAS ben able to boot into BIOS previously (never had it fully installed though), with an Intel DX4-100MHz CPU (SK096).
One thing that puzzles me, is that the jumper for selecting between 3.3V and 5V is missing and instead bridged. First, I assumed that it was able to automatically select it since it wasn't selectable, but after seeing a thread here where someone was reinstating the power regulator on the same board (and another one here), I'm no longer too sure. Is this board only usable with 5V CPU's, or Overdrive CPU's with the power regulator on top of it?
Anyway, I have been trying with three different 5V CPUs (SX759, SX645 and SX790), and can't get it to boot with any of them. I never get anything on display, even with different display adapters in different slots. I also tried different and fewer memory dimms.
I use the jumper settings from this site, even though it states it's for a rev 1.1, but unlike in the official manual, the pins are matching the board.
When I plug in a PC analyzer card that I have, it gets stuck at C5 C1 (with and without display adapter), but those codes doesn't make a lot of sense to me. C5 seems to indicate "OEM Specific - Early Shadow enable for fast boot" and perhaps "OEM Specific - Test to Size On-Board Memory" if I read it correctly. I have attached the manual here.
[/url]
Can anyone recommend me what my next steps is to troubleshoot the problem. I'm not too good with a multimeter, but I do have a good one, if anyone can guide me as to where to measure something.
