First post, by BastetFurry
Hey Vogons 😀
I have a Tidalwave PS-1000 clone, a Okano PT-100, in front of me where i want to use either CF-Cards trough a passive adapter or Flash Cards, maybe even both.
The problem is, tellme.com isn't recognizing the PC Card chipset, see "screenshot" for the output. Darn hard to photograph these old screens. 😅
Any ideas how to get the two PC Card slots in that machine to recognize more than these darn way too expensive SRAM cards?
    393.85 KiB
    "Screenshot" of tellme.com
Reply 1 of 8, by ajacocks
Interesting...I just picked up a Zeos Pocket PC, though it seems to need cleaning, since it doesn’t power up on battery.
Do you have manuals, or the parallel or serial cables? I don’t have any of them, and would like to try to clone the serial cable, at least.
- Alex
Reply 2 of 8, by BastetFurry
Nope, just got the device in its leather bag, had to get myself a used aftermarket solution that is just for the Tidalwaves utilizing a very thin PCB instead of some special cable adapter.
Reply 4 of 8, by BastetFurry
The image is too big for the forum, check it out over here:
http://lionscade.de/zeugs/tidalwaveportreplicator.jpg
BTW, you can abuse Dosbox running Norton Commander to get files from and to the device over serial, works rather nicely. 😉
