First post, by Smack2k
Hoping someone with better knowledge of chipsets can answer this
If I am installing a Pentium 2 233 system, is using my ASUS P2B with the 440BX chipset going to give me a decided advantage over using a Gigabyte 686-LX4 board with the 440LX chipset?
I don't want to use a faster Proc for the build as this is going to replace the Pentium MMX 233 that I had planned but was shipped a bad board on eBay that burned the Proc and slot upon powering it on (trying for refund but that takes a while), so the 233 P2 is what I am going to run.
Just don't know if I am wasting the P2B or if it is a good choice over the 440LX
Reply 2 of 6, by appiah4
You will have absolutely no practical benefit from going with the BX board over LX with a 66MHz FSB CPU aside from AGP 2x which likely wont matter with the CPU bottleneck. It alao has ECC support if you use that I guess.
Reply 3 of 6, by Thermalwrong
Probably better to use the P2B for a faster build, the 233 is well suited to the LX chipset - my current favourite PC (because of integrated OPL4) has an LX chipset motherboard, it came with a PII 233 and works pretty well overall.
The P2B might have better options for underclocking / disabling cache though, so check the manuals for each to see if they allow disabling L1 / L2 cache, or just disabling all cache.
Reply 4 of 6, by Smack2k
That is what I was looking for....
Still debating though as I have no plans to do that right now as I am trying to keep the number of running, built retro PCs down to 5 or 6 core machines that have best performance I can do on each, but who knows if I will get the urge to build something between the 233 and my 1.266 P3 machine....If I don't build anything else between them then using the P2B would be the best build for the 233 for maximum performance.....but knowing myself, once this is built I'll want to build something else!
The underclocking features are something I didn't think about though. Will have to look over the P2B and gigabyte manuals to see what they can do
Reply 5 of 6, by Thermalwrong
That's the nice thing about slot1 - especially BX boards that can set multiplier / FSB, it can with suitable bios support, handle processors from the P-II 233 up to the coppermine P-IIIs, and they're easy to swap out.
Also, some of the older Intel CPUs are unlocked, so can be underclocked via multipliers, which is discussed here, with the P2B: Quick question about underclocking a Pentium 2
edit: and here Which Pentium IIs can be underclocked?
