First post, by TimWinGame
I’ve got a 386dx 25 MHz machine with 4 megs of RAM. After adding a SoundBlaster 16 and enabling sound in some games, it is dragging a bit. In Epic Pinball for instance, it runs smooth and slick with just the PC speaker but it gets sluggish with SB sound enabled. My motherboard (BT-3mm 5.5) won’t support a faster 386, but I could add more RAM. Is that likely to help the situation, or is the CPU the bottleneck?
